Click HERE to order or for more information.
ECS Heavy Duty Cast Aluminum Thermostat Housing -
As many 1.8T owners know, the factory plastic thermostat housing is a common point of failure for the cooling system. This is largely due to constant heat cycling which causes the factory plastic to heat-harden, become brittle, and eventually warp or crack.
In-House engineered by ECS Tuning, we gladly introduce the Heavy Duty Cast Aluminum Housing. Aside from the obvious change in material, our cast alloy housing includes a larger bore for increased flow, and post machined mounting surfaces for optimum sealing capabilities.
The last housing you'll ever need!
http://www.ecstuning.com :: Phone: 1.800.924.5172 - Hours:Mon. - Fri. 8:00AM - 11:00PM Sat. 10:00AM - 7:00PM EST :: Email: sales@ecstuning.com & customerservice@ecstuning.com :: Facebook :: YouTube :: Live Chat :: Instagram
