Click HERE to order or for more information.
Clutch Kits for your VW B5 Passat 1.8T -
Why not replace your worn stock clutch with something special?
Three stages & driving styles are accommodated for, allowing you to carefully choose the exact clutch for your needs.
We have three great clutch conversion kits built around our ECS-engineered lightweight RA4 flywheel. This lightweight design reduces rotational mass for faster revs off idle, while its larger clutch contact surface improves clamping for better power transfer.
Improved low-end throttle response. Smooth operation. Less lost power off the line. Stronger and tougher than the original.
