Results 1 to 7 of 7
Thread: Old Skool Coils!! NJT Extreme Coilover kits - MK1, MK2, MK3
    Sep 2011
    New South Wales
    Struggling to find decent coilovers for your Old Skool ride.. we got you covered.
    NJT eXtrem Coilover Suspension Kits
    Hardness and height adjustable coilover kits, 16-point hardness adjustable, TÜV-adjustment range from 20 to 60 mm for a perfect road holding in every situation. eXteme ride quality! With the exclusive performance-control screw you choose between 16 individual hardness degrees from eXtremly sporty to comfortable.
    19.3 TÜV approved
    Height and hardness adjustable
    High quality components
    Cold wound springs
    aAdjustment range 20 to 60mm
    PRICE: $1220.00
    Order here (bottom of the page) : Suspension-Workshop
    Is the hardness adjustment linear (smooth) or is there a click between the 16 settings?
    Sep 2011
    New South Wales
    We will check this out for you today. I have only played with an uninstalled kit once, i think it's linear. Will confirm later.
    Thanks
    Sep 2011
    New South Wales
    It's Linear
    Jan 2007
    Hi SK,
    How much better are these struts over the entry level JOM Bluelines?
    Would you recommend these over the Bluelines for daily driving?
    I don't need a huge drop and car will be used for mostly country roads and highways- so a mix of road quality.
    07 GTI
    APR stage II
    Sep 2011
    New South Wales
    Quote Originally Posted by golfmeup View Post
    Hi SK,
    Sorry for the delay. The build quality on these are better obviously. The Blueline provides a fairly comfortable ride quality with limited settings. But these, you have a few more settings to play with to get it just right. I think the spring rate is a bit higher on these causing them to be a bit stiffer ride wise. But again the build quality and more settings is what you are paying for. But again, for the price of the Blueline's, they are awesome.
    Jan 2007
    Cheers!
    07 GTI
    APR stage II
