Is the hardness adjustment linear (smooth) or is there a click between the 16 settings?
Old Skool Coils!! NJT Extreme Coilover kits - MK1, MK2, MK3
Struggling to find decent coilovers for your Old Skool ride.. we got you covered.
NJT eXtrem Coilover Suspension Kits
Hardness and height adjustable coilover kits, 16-point hardness adjustable, TÜV-adjustment range from 20 to 60 mm for a perfect road holding in every situation. eXteme ride quality! With the exclusive performance-control screw you choose between 16 individual hardness degrees from eXtremly sporty to comfortable.
19.3 TÜV approved
Height and hardness adjustable
High quality components
Cold wound springs
aAdjustment range 20 to 60mm
PRICE: $1220.00
Order here (bottom of the page) : Suspension-Workshop
It's Linear
Hi SK,
How much better are these struts over the entry level JOM Bluelines?
Would you recommend these over the Bluelines for daily driving?
I don't need a huge drop and car will be used for mostly country roads and highways- so a mix of road quality.
07 GTI
APR stage II
Sorry for the delay. The build quality on these are better obviously. The Blueline provides a fairly comfortable ride quality with limited settings. But these, you have a few more settings to play with to get it just right. I think the spring rate is a bit higher on these causing them to be a bit stiffer ride wise. But again the build quality and more settings is what you are paying for. But again, for the price of the Blueline's, they are awesome.
Cheers!
07 GTI
APR stage II
