Results 1 to 4 of 4
Thread: License Plate LEDs (2pc)
    Sep 2011
    New South Wales
    ORDER HERE: License plate LEDs 2pcs | SlickOnline - AutoSlick & HomeSlick
    Give more light to your license plate with JOM LED license plate bulbs. Plug & play!
    E-marked
    18 LED/side
    super bright light
    1 set, 2 pieces
    compatible to boardcomputer / canbus
    plug & play
    brisbane
    could you tell me if these would fit an audi s3 8p 3 door please. its a 2010 model and i have heard that on later models the led lights can throw codes?
    Have you guys got any real photos of these lights fitted to a Golf 6 (or similar) at night time. Would be nice to see how the light appears (eg: does the light from the 3 individual LED's create a constant beam or can you see 3 separate smaller beams?)
    Ive had the OEM LED numberplate lights on my Golf 6 which were a twin LED setup, but the output was a bit weak and you could quite easily see the 2 separate beams of light from each LED chip. I now have the Racing Dash LED's which have a much stronger light output, but perhaps a little too strong. These new ones you are offering might be a good compromise.
    Sep 2011
    New South Wales
    Ive had the OEM LED number plate lights on my Golf 6 which were a twin LED setup, but the output was a bit weak and you could quite easily see the 2 separate beams of light from each LED chip. I now have the Racing Dash LED's which have a much stronger light output, but perhaps a little too strong. These new ones you are offering might be a good compromise.
    Hi Lucus thanks for your message, we actually do not have any real photos of these lights fitted yet, but I can get photos for you for the lights that we do have in stock, but for the ones from JOM Germany, we currently do not have any stock at the moment. We would be getting them shortly so until then we are unable to get photos of it.
    Sorry for any inconvenience, we will keep you updated as soon as possible.
    Thanks JN
