CPI Tuning - Slickonline remapped!!
Hi All, we have been in the process of taking on and setting up our next exciting chapter in Slickonline.
CPI Tuning Explained
CPI Port Tuning Explained
Simple process. We retrieve your original, unmodified ECU software file.
Your file is sent to our Technician in South Africa.
The file is then optimised to produce the best output for the hardware and internals you have installed on your car.
The file is sent back to us and we load the file back to your car.
CPI PNP Units Explained by the Master Tech and owner of CPI
To our Valued Customer and Fans,
Our PNP units can control up to 4 signal channels which we only utilise 3 for the G7 GTI to control the fuel and boost.
Quite to the contrary of many people’s beliefs our PNP unit is not a bunch of resistor's in a box with jumpers.
If you had a close look at our unit there are no Jumpers and the unit is completely sealed to eliminate any tampering.
The electronics are protected within a waterproof moulded unit which is almost indestructible.
If anyone has had the opportunity to open any inferior PNP unit you would have noticed that they are not capable of controlling multiple channels due to the lack of technology.
Now I’m not going to explain how our PNP units internal high-performance, low-power microcontroller which is capable of executing powerful instructions in a single clock cycle actually controls the signals, but I will tell you that we are capable of changing the code in the unit to control boost and fuel at desired load points that we choose to manipulate.
We do utilise a custom tuning interface to tune the PNP unit which gives us full control over the unit.
In a nutshell think of our PNP unit in the lines of a non-intrusive piggyback system.
IMPORTANT! Newer European and even Japanese cars run encrypted ECU's. Our PNP units are designed to work with these cars WITHOUT decrypting expensive ECU's and potentially bricking your car. Our units are undetectable by factory diagnostics when a 5-10min removal process is followed. Please make an informed decision on what tune you want by considering potential issues you might find after someone has tapped into your ENCRYPTED ECU!
It's always hard introducing new products and brands to the market. Especially the Aussie market as we all know we are fussy and want things done right. We will be happy to answer any questions you have so fire away. Obviously the technology for our PNP units are going to be questioned, but we are happy to discuss.
We are going to try to keep things simple. We will be putting a few of our CPI tuned cars on the Dyno an down the quarter mile in the coming months. You can make an informed decision if CPI is for you.
If you have any requirements for your car, please contact us. We have the following CPI products on the way.
- Downpipes
- Cold Air Intakes
- Water-Meth Kits
- Coil Packs
- Intercoolers
- Big brake kits
- Etc....
- You may not post replies
- You may not edit your posts
Forum Rules
