Results 1 to 6 of 6
Thread: Bullet HD Action Cameras
    Sep 2011
    New South Wales
    The BulletHD PRO1080P is the world's first actioncam with motion stabalizer, all videos will be sharper and therefore more stable and thanks to the noise you sound better than ever!
    A waterproof aluminum housing ensures no circumstances will you be able to stop, it's waterproof and shockproof! Optionally you can choose in low noise for the standard supplied sound-cap.
    CHECK ALL AROUND THE FISHEYE LENS
    The fish eye lens BulletHD provides the perfect balance between viewing the entire environment and avoiding distortion of your image. A perfect capture!
    HD VIDEO ACTION
    With a choice of recording in 1080P @ 30FPS and 720P @ 60 FPS is always a recording mode that is perfect for you!
    The BulletHD PRO1080P records video directly to a MicroSD card. With a maximum support of 32 GB on your MicroSD card 1 single over 5 hours of AVI video. Approximately 1GB per 10 minutes.
    ANYWHERE TO USE
    With our wide range of fasteners, what you stand for your BulletHD PRO1080P gets BulletHD PRO1080P you can use anytime and anywhere, whether it's to your helmet, handlebars or car.
    EASY TO USE
    Easier than this is not a simple large button to the BulletHD PRO1080P to use even with gloves on is no problem!
    RECHARGEABLE
    By default you get 2 rechargeable lithium batteries in your BulletHD, a full battery allows for recording up to 5 hours!
    Lite 2
    Order here: Bullet HD Lite 2 - ACTION CAM | SlickOnline - AutoSlick & HomeSlick
    LENS
    - 135 degrees Wide Angle, 720P
    VIDEO
    - HD Resolution: 720p: 1280 x 720 pixels, 25fps
    - Video format: MPEG codec. AVI file format
    - Exposure Control: Auto / Center Weighted / Spot
    - White balance: Auto
    AUDIO
    - Mono, 48 kHz, AAC compression, microphone (optional cap for more sound recordings)
    - Resolution: 2592 x 1944 pixels
    - Camera: 5 Megapixels
    - File format: JPEG
    - Recording mode: Auto snap shop every 3 seconds
    STORAGE
    - Memory: MicroSD card up to 32GB, Class 6 or higher
    - Average recording time: 10 ~ 15 min per GB
    DIMENSIONS
    - Size: 83 x 30 x 30 mm
    - Weight: 83 g (99 g with battery and micro SD card)
    - Water resistant (waterproof when using other shell)
    1. Camcorder with Sound Cap (water resistant)
    2. Camcorder Mount
    3. Universal Mount
    4. Roll Bar Mount
    5. Battery
    6. Adhesive stickers 2pcs
    7. USB Cable
    8. Hand safety Strap
    9. User Manual
    10. Waterproof Cap
    11. Rubber O-ring 6pcs
    12. Silicon Grease
    Bullet HD 2 720p
    Order here: Bullet HD 2 720p - ACTION CAM | SlickOnline - AutoSlick & HomeSlick
    Technical Specifications
    12 Megapixel
    HD Video Resolution 720p
    (1280x720 Pixel)
    170° optical fisheye lens
    10 m water proof
    With Photo Capture Mode:
    Camera takes a photo every 3 seconds
    integrated microphone
    Aluminum housing
    Optics:
    FISHEYE view
    f/2.4, fixed focus glass lens
    HD Resolution Settings: 720p: 1280x 720 @30fps
    Sensor Type: 1 / 2.5” HD CMOS
    Light Sensitivity: 1.4 V/lux-sec (550nm)
    Video Format:
    MJPG codec, .AVI file format
    Exposure Control : Auto
    White Balance: Auto
    Audio:
    Built-in microphone
    Photo:
    Resolution: 4032 x 3024
    Camera: 12.0 Mega Pixels
    Format: JPEG
    Capture mode: Auto snapshot every 3 seconds
    Storage:
    Memory: Micro SD card, support Max up to 32GB capacity
    (recommended Class 6 or above)
    Avg. Record Time: 10~15min/GB
    Product size:
    92 x 30 x 30 mm
    Weight: 99g
    Operating System (for USB drive):
    Win ME, 2000, XP, Vista, 7; Mac OS X 10.6+
    WHATS IN THE BOX:
    Camcorder Mount
    Universal Mount
    Roll Bar Mount
    Pad Mount
    Battery 2pcs
    USB Cable
    Adhesive stickers 6pcs
    Magic Tape 2pcs
    Hand safety Strap
    User Manual
    Waterproof Cap
    Rubber O-ring 6pcs
    Silicon Grease
    Bullet HD Pro 1080p
    Order here: Pro Bullet HD 2 - ACTION CAM | SlickOnline - AutoSlick & HomeSlick
    Features:
    Rechargeable Swappable Battery
    12.0 Mega Pixel Camera with Image Stabilization
    Full HD 1080p Video Recording
    Waterproof: Up to 30 Feet
    Fire Resistant: Up to 950°F
    Vibration & LED Mode Indicators - Power on: 1 long vibration; start recording: 1 short vibration; stop recording: 3 short vibrations; power off: 2 short vibrations)
    Specifications:
    Optics:
    Photo mode: 170° - Fisheye view
    Video mode: 135° - Wide angle view
    f/2.8, fixed focus glass lens
    Video :
    Full HD Resolution Settings - 1080p: 1920x1080 @ 30fps
    HD Resolution (Slow Motion) Settings - 720p: 1280x720 @ 60fps
    Digital Video Motion Stabilization Technology
    Sensor Type: 1/ 2.5" HD CMOS
    Video Format: H.264 / MPEG-4
    Exposure Control: Auto / center weighted / spot
    White Balance: Auto
    Audio :
    Built-in microphone
    Photo :
    Resolution: 4032x4024
    Camera: 20.0 Mega Pixels
    Format: JPEG
    Storage :
    Memory: Micro SD card, up to 32GB capacity (not included (recommended Class 6 or above)
    Avg. Record Time: 10-15min/GB
    Product size: 104 x 32 x 32 mm
    Weight: 105g
    Operation System (USB Drive): Win ME, Win7, 2000, XP, Vista; Mac OS X 10.6+
    Operation System (Webcam): Win7, XP, Vista
    2. Camcorder Mount
    3. Universal Mount 3pcs
    4. Roll Bar Mount
    5. Pad Mount
    6. Rotating Kit Set
    7. Battery 2pcs
    8. USB Cable
    9. Adhesive stickers 8pcs
    10. Magic Tape 2pcs
    11. Hand safety Strap
    12. User Manual
    13. Waterproof Cap
    14. Rubber O-ring 6pcs
    15. Silicon Grease
    Apr 2010
    Got any sample videos filmed with these cameras?
    Sep 2011
    New South Wales
    Ryan,
    I will get AK to find the videos he took on his last trip with this camera and see if we can get them uploaded.
    Sep 2011
    New South Wales
    Sep 2011
    New South Wales
    Sorry.. just further to the Video post above... NOTE: The Camera right in the beginning (shots of the parked cars) and the one mounted on the Ibiza with the BLACK hood is the Bullet HD. The camera mounted on the full red ibiza, including the interior is a GoPro.
    Sorry for the crap upload quality. It's just proof that the Bullet HD and GoPro are very similar in video quality. The Bullet HD being the more sturdy unit in my opinion.
    Apr 2010
    Thanks - I asked more to help other visitors of this thread. I already have a GoPro that I seldom use. One day I might get a more permanent camera to put behind the mirror if I find a good one.
