Got any sample videos filmed with these cameras?
The BulletHD PRO1080P is the world's first actioncam with motion stabalizer, all videos will be sharper and therefore more stable and thanks to the noise you sound better than ever!
A waterproof aluminum housing ensures no circumstances will you be able to stop, it's waterproof and shockproof! Optionally you can choose in low noise for the standard supplied sound-cap.
CHECK ALL AROUND THE FISHEYE LENS
The fish eye lens BulletHD provides the perfect balance between viewing the entire environment and avoiding distortion of your image. A perfect capture!
HD VIDEO ACTION
With a choice of recording in 1080P @ 30FPS and 720P @ 60 FPS is always a recording mode that is perfect for you!
The BulletHD PRO1080P records video directly to a MicroSD card. With a maximum support of 32 GB on your MicroSD card 1 single over 5 hours of AVI video. Approximately 1GB per 10 minutes.
ANYWHERE TO USE
With our wide range of fasteners, what you stand for your BulletHD PRO1080P gets BulletHD PRO1080P you can use anytime and anywhere, whether it's to your helmet, handlebars or car.
EASY TO USE
Easier than this is not a simple large button to the BulletHD PRO1080P to use even with gloves on is no problem!
RECHARGEABLE
By default you get 2 rechargeable lithium batteries in your BulletHD, a full battery allows for recording up to 5 hours!
Lite 2
Order here: Bullet HD Lite 2 - ACTION CAM | SlickOnline - AutoSlick & HomeSlick
LENS
- 135 degrees Wide Angle, 720P
VIDEO
- HD Resolution: 720p: 1280 x 720 pixels, 25fps
- Video format: MPEG codec. AVI file format
- Exposure Control: Auto / Center Weighted / Spot
- White balance: Auto
AUDIO
- Mono, 48 kHz, AAC compression, microphone (optional cap for more sound recordings)
- Resolution: 2592 x 1944 pixels
- Camera: 5 Megapixels
- File format: JPEG
- Recording mode: Auto snap shop every 3 seconds
STORAGE
- Memory: MicroSD card up to 32GB, Class 6 or higher
- Average recording time: 10 ~ 15 min per GB
DIMENSIONS
- Size: 83 x 30 x 30 mm
- Weight: 83 g (99 g with battery and micro SD card)
- Water resistant (waterproof when using other shell)
1. Camcorder with Sound Cap (water resistant)
2. Camcorder Mount
3. Universal Mount
4. Roll Bar Mount
5. Battery
6. Adhesive stickers 2pcs
7. USB Cable
8. Hand safety Strap
9. User Manual
10. Waterproof Cap
11. Rubber O-ring 6pcs
12. Silicon Grease
Bullet HD 2 720p
Order here: Bullet HD 2 720p - ACTION CAM | SlickOnline - AutoSlick & HomeSlick
Technical Specifications
12 Megapixel
HD Video Resolution 720p
(1280x720 Pixel)
170° optical fisheye lens
10 m water proof
With Photo Capture Mode:
Camera takes a photo every 3 seconds
integrated microphone
Aluminum housing
Optics:
FISHEYE view
f/2.4, fixed focus glass lens
HD Resolution Settings: 720p: 1280x 720 @30fps
Sensor Type: 1 / 2.5” HD CMOS
Light Sensitivity: 1.4 V/lux-sec (550nm)
Video Format:
MJPG codec, .AVI file format
Exposure Control : Auto
White Balance: Auto
Audio:
Built-in microphone
Photo:
Resolution: 4032 x 3024
Camera: 12.0 Mega Pixels
Format: JPEG
Capture mode: Auto snapshot every 3 seconds
Storage:
Memory: Micro SD card, support Max up to 32GB capacity
(recommended Class 6 or above)
Avg. Record Time: 10~15min/GB
Product size:
92 x 30 x 30 mm
Weight: 99g
Operating System (for USB drive):
Win ME, 2000, XP, Vista, 7; Mac OS X 10.6+
WHATS IN THE BOX:
Camcorder Mount
Universal Mount
Roll Bar Mount
Pad Mount
Battery 2pcs
USB Cable
Adhesive stickers 6pcs
Magic Tape 2pcs
Hand safety Strap
User Manual
Waterproof Cap
Rubber O-ring 6pcs
Silicon Grease
Bullet HD Pro 1080p
Order here: Pro Bullet HD 2 - ACTION CAM | SlickOnline - AutoSlick & HomeSlick
Features:
Rechargeable Swappable Battery
12.0 Mega Pixel Camera with Image Stabilization
Full HD 1080p Video Recording
Waterproof: Up to 30 Feet
Fire Resistant: Up to 950°F
Vibration & LED Mode Indicators - Power on: 1 long vibration; start recording: 1 short vibration; stop recording: 3 short vibrations; power off: 2 short vibrations)
Specifications:
Optics:
Photo mode: 170° - Fisheye view
Video mode: 135° - Wide angle view
f/2.8, fixed focus glass lens
Video :
Full HD Resolution Settings - 1080p: 1920x1080 @ 30fps
HD Resolution (Slow Motion) Settings - 720p: 1280x720 @ 60fps
Digital Video Motion Stabilization Technology
Sensor Type: 1/ 2.5" HD CMOS
Video Format: H.264 / MPEG-4
Exposure Control: Auto / center weighted / spot
White Balance: Auto
Audio :
Built-in microphone
Photo :
Resolution: 4032x4024
Camera: 20.0 Mega Pixels
Format: JPEG
Storage :
Memory: Micro SD card, up to 32GB capacity (not included (recommended Class 6 or above)
Avg. Record Time: 10-15min/GB
Product size: 104 x 32 x 32 mm
Weight: 105g
Operation System (USB Drive): Win ME, Win7, 2000, XP, Vista; Mac OS X 10.6+
Operation System (Webcam): Win7, XP, Vista
2. Camcorder Mount
3. Universal Mount 3pcs
4. Roll Bar Mount
5. Pad Mount
6. Rotating Kit Set
7. Battery 2pcs
8. USB Cable
9. Adhesive stickers 8pcs
10. Magic Tape 2pcs
11. Hand safety Strap
12. User Manual
13. Waterproof Cap
14. Rubber O-ring 6pcs
15. Silicon Grease
Sorry.. just further to the Video post above... NOTE: The Camera right in the beginning (shots of the parked cars) and the one mounted on the Ibiza with the BLACK hood is the Bullet HD. The camera mounted on the full red ibiza, including the interior is a GoPro.
Sorry for the crap upload quality. It's just proof that the Bullet HD and GoPro are very similar in video quality. The Bullet HD being the more sturdy unit in my opinion.
Thanks - I asked more to help other visitors of this thread. I already have a GoPro that I seldom use. One day I might get a more permanent camera to put behind the mirror if I find a good one.
