FORUM SPECIAL: Usually $149.95 now discounted to $119.95
ORDER HERE - Use the discount code "take30" to take advantage of the forum special.
Stop thinking about it and jump in a get one! A good quality charger can be exceptionally helpful whether its to recharge a dead battery or to keep the charge topped up in your race car.
Info
An intelligent battery charger suitable for flooded and gel lead acid batteries including deep cycle batteries at 6V, 12V or 24V. The microprocessor controlled unit provides 4 stages of charging, Soft Start, Bulk Charge, Absorption and Float which assists in the batteries life expectancy and performance. An auto detection feature provides a user friendly experience, which can be pre-programmed or manually set for greater control. Should a blackout occur or AC input power be lost during a charging operation the memory function will resume charging once power is re-established. Other features include temperature/voltage compensation, reverse polarity/short circuit protection and a battery status indicator. Ideal for cars, motorcycles, caravans and boats with battery capacities between 20-200Ah. It's also ultra-portable with a handy storage pocket in the back for the leads.
Features:
• Memory function
• Temperature controlled fan
• LED battery status display
• Temperature and voltage compensation
Protection:
• Anti spark
• Short circuit
• Reverse polarity
• Over heating/current/voltage
Specifications:
• Input: 220 - 240VAC, 300W
• Output:
- 15A @ 12V
- 7A @12V/24V
- 2A @ 6V/12V/24V
• Dimensions: 230(H) x 170(W) x 140(D)mm
