SPM MK6 GTI Spring Kit and Rear Swaybar kit
Includes:
SPM Mk6 GTI 28mm Spring Kit
SPM MK5/6 GTI Rear Swaybar Bar
Combined individual purchase price: $558
Special bundle price:$499
Saving: $59
Offer ends: When sold out!
SPM progressive rate lowering springs are manufactured to meet the highest standards using 54SiCr6 spring steel to ensure quality and performance.
Our spring rates as measured on the Longacre spring compressor measure 42% stiffer than OEM and will lower your GTI by 28mm front and rear, giving you a lower center of gravity, reduction in body roll, and increase that sporty feel missing while using OEM springs. The amount our springs lower your ride height and the 42% increase in stiffness over OEM make these a great match, even with OEM dampers.
This is a great, complete modification for those looking to improve steering response, reduction in body roll, and aesthetic improvements all while giving your MK6 GTI that sporty look and feel.<p>
The SPM 24mm adjustable rear sway bar significantly increases wheel spring stiffness during body roll; cornering response is increased while body roll and understeer are reduced without compromising ride comfort.
When dealing with FWD vehicles an upgraded rear sway bar is arguably the best suspension modification one can commit to.
SPM bars offer three settings allowing them to be tailored to your specific needs: soft, medium, and hard. The solid construction and lever arm length with adjustable mounting locations found in our bars provide a 32%, 47%, and 62% increase in stiffness over OEM.
They’re a great compliment to our SPM spring kit, as well as other spring kits and coilovers. All SPM adjustable sway bars come complete with necessary mounting hardware, brackets, Teflon lined bushing, and bushing lubricant.
