Hey Tim, will the Torque arm insert (MK5) fit a Tiguan with the 2.0 TFSI motor?
And
will the Transmission inserts (Stg1) for the MK5 fit as well? Considering its a 4motion setup ?
Thanks
There should be no fitment issues on any of the local mk4 models
And
Thanks
I believe fitment is the same on the Tiguan as with the MKV unfortunately most Tiguans are probably the MY09 style. VW have decided to change their OE Mount design so BFI are in the process of redesigning the Torque arm insert to suit. If yours in an MY09 you may be able to source a Neuspeed one from Rennenhaus as they are quick to the market with an updated design.
Ive stolen some pics here from andrews APR TAI install thread and the neuspeed site. Have a look and you should be able to check yourself what your car is running.
up to MY08 uses this mount.
MY09 cars are using this mount
As for the trans mount I have not had any dealings with the tiguan in that area unfortunately. BFI do not list the Tiguan as a supported model. Here are the install instructions anyways. May give you an indication of its compatibility.
http://www.dubaddiction.com.au/linke...structions.pdf
The stage1 trans mount will induce some vibration though. Some people dont mind it for the sake of performance as it actually makes the car feel purposeful but others like to have a cry at the slight loss of passenger comfort.
The above specials have now expired!
But for the coming month Dub Addiction will be running the following items at discounted prices!
http://www.dubaddiction.com.au/index..._page=specials
Specials
Polo 9N Dash Cubby
WAS $79.95
NOW $71.95
Save: 10% off
Lower stress brace mk2
WAS $119.00
NOW $101.15
Save: 15% off
Inpro Smoked Mirror Indicator Lenses
WAS $69.95
NOW $62.95
Save: 10% off
Fast Badge
WAS $29.95
NOW $23.96
Save: 20% off
Mattig Headlight Brows
WAS $48.00
NOW $38.40
Save: 20% off
Kamei Headlight Brows
WAS $69.95
NOW $55.96
Save: 20% off
Gruven Parts MK4 Billet Hood Pull
WAS $79.00
NOW $63.20
Save: 20% off
BFI MK3 Stage 1 Engine Mount Kit
WAS $249.00
NOW $199.20
Save: 20% off
big thanks to Tim for quick shipping on the stress bar! even tho i never fitted it like planned LOL
Hi Tim, any chance of sourcing some cheap lower honeycomb grills for the current 9N polo?
Cheers,
Anthony.
At this stage not likely. I believe those are coming from china and my Chinese sucks almost as bad as their English
