Just received a shipment from BSH today. New to the Dub Addiction product lineup is the BSH Stage 1 PCV Revamp.
As with all BSH items it will be on special until the end of the month.
RRP $119
Currently $107.10 Save: 10% off
Designed with simplicity of install in mind the BSH Bulletproof PCV Revamp kit takes care of the commonly occurring PCV issues in tuned 2.0T applications. Manufactured here in the USA, the CNC machined BSH Bulletproof PCV Revamp fixes the major problems with the 2.0T PCV system once and for all!
The prone to failure factory PCV system has long plagued this engine with poor mpg, rough idle, boost loss, and the dreaded oil spewing from the oil cap. The BSH Bulletproof PCV revamp ensures these issues will never affect your engine again by converting the system to a vacuum only based system. PCV function is properly retained and no emissions functions are tampered with this modification.
Includes:
Billet Valve Cover Plate
Billet PCV Adapter
Billet Manifold Cap
O-Rings
Retaining Hardware
Notes:
Installs in under an hour
Fully Compatible with BSH Boost Tap
