Results 1 to 9 of 9
Thread: What is the difference between...
    dj_daniel88 Guest
    Hi everyone,
    I am going to look at a 1998 Audi A3 turbo this weekend. It has only done 100,000 km's.
    There is another one I will look at, a 2000 A3 turbo. Was there any variations between these years? I noticed that the climate control units are different in the pictures...
    The 2000 one has 150,000 kms on it. It has a sun roof too. They are for the same price.
    If I knew a bit more about the differences between the years it would help me make my decision.
    Thanks guys!
    I reckon the 2000 model might be a drive by wire one, that has a variable valve timing head on it.
    Get the engine numbers from the service book to check this. The 1998 will be an AGU engine for sure, the 2000 probably isn't.
    dj_daniel88 Guest
    So which would be the better one? If I look on carsales for the specs of the '98 one, it says :
    Variable valve actuation: Variable timing
    http://www.carsales.com.au/car-research/details.aspx?Model=A3&__N=4294967194+4294967193+42 94902369+281&__sid=11335BFCB7DA&seot=20&__Nne=20&s ilo=1005&Make=AUDI&Cr=2&trecs=4&R=cs19980205.12:04 :40&__Ns=pCar_YearMade_Int32|1||pCar_Make_String|0 ||pCar_Model_String|0
    gpk_gti Guest
    try going to www.redbook.com.au for some specs,im not familiar with the a3 range.
    dj_daniel88 Guest
    Thanks I didn't know the redbook had specs.
    So both have the 'AGU' engine. Is there anything wrong with this engine, or anything I should look out for?
    gpk_gti Guest
    mine has the agu motor(sweet motor,no major hassles) and is cable driven,not drive by wire. which one had the variable valve timing?? that would be better,but it has more k's right?
    have you looked at the a3 thats forsale on here???
    gpk_gti Guest
    also have you tried looking here,as more audi freaks hang around there! haha
    http://www.ozaudi.com/nuke/modules.p...=viewforum&f=3
    not trying to ditch ya,,but maybe you will get more info quicker there.personally I would stay with the gti! but im biased!
    dj_daniel88 Guest
    hey thanks for the link!
    Why would you go for the gti over the audi? I'm looking for others opinions to help make a dicision. Tomorrow I'm going to look at both a gti and an a3.
    syncro Guest
    A '98 has two doors.
    2000 has four.
