Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Swapping ECUs
    Feb 2009
    Alright I tried again with Ross-tech's instructions.
    It does the read/save fine with no errors.
    Turn off the ignition for up to 5minutes and it still will not start or align the immo/ID.
    Will this work?
    http://www.goapr.com.au/support/immobilizer.html
    I will give it a try.
    Btw this ECU is from the UK, but the softcoding is all the same (as well as the ECU number). Maybe you should know??
    00 A4 1.8TQMS GT2871R powered - Gone
    BMW 1M
    MK7 '19MY Golf TSI Trendline
    Feb 2009
    Check out this post:
    http://www.ozaudi.com/forums/showpos...5&postcount=33
    Specifically: terminal 30 reading low voltage
    I get this as well with the other ECU. Is it faulty? Can it be repaired?
    BMW 1M
    Quote Originally Posted by gmx View Post
    The ECU recognises that you unplugged it with the battery connected, that's all. Delete that code and it'll stay away.
