Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: S3 1.8t boost problem / should apply to other 1.8t VAG motors
    Quote Originally Posted by IanPGonzaga View Post
    No need to change the main one from removal of the cover?
    They usually come as a pair.
    Dec 2007
    Melburg East VIC
    do the whole set incl half moon seal
    1.8T AGU | K04 | GIAC | 380cc | VR6 MAF | Custom Intake | FMIC | TIP | 3bar FPR | N75J | 42DD 3-2.5" TB | GFB DV | FK Highsport | ECS Stage 1 Clutch | OZ FUTURA
    May 2015
    A.k.a timing chain tensioner gasket?
    AUDI 058198217, gasket set for chain: Cart Part Info
    May 2015
    ok so changed all 4 coil packs to the TFSI (07K905715F) ones that sit a little bit taller and went for a drive... BOOOOO i still had hesitation and it felt worse.... scanned and the error moved to cylinder 4!
    WTF?
    so i thought i had a dodgy set of TFSI coil packs - opened the bonnet and the connector wasn't pushed in properly. ha!
    so plugged it in and got going.
    running super smooth now all the way up to red line
    no sign of hesitation and logged for boost leaks using VCDS - requested and actual look good! car feels great!!! super stoked with that as i was about to bail on the car if that wasn't successful! lol
    now... to get this SKC business sorted out...
    Mar 2011
    Inner West, NSW
    Did you also get the TFSI "mounting plate"? It just bolts on to the rocker and ensures that the coilpacks don't jump out or move
    May 2015
    yep got the spacers from a local dealer (approx. $40) and grinded them down so they sit flush on the cam cover.
    Attached Thumbnails Attached Thumbnails S3 1.8t boost problem / should apply to other 1.8t VAG motors-p1300129-jpg
