Results 1 to 10 of 16
Thread: S3 1.8t boost problem / should apply to other 1.8t VAG motors
    May 2015
    Question S3 1.8t boost problem / should apply to other 1.8t VAG motors
    hey guys have a look/listen to this video
    anyone else had this problem car pulls great up until 5k in 1st then power clearly isn't being made anymore along with the throttle sounding like it's not continuously take air in but quickly on/off/on/off/on/off. then in 2nd and 3rd it's happening at about 4k - 4.5.k
    Quote Originally Posted by IanPGonzaga View Post
    Why is your ESP light on?
    What engine code?
    Sounds like there might be a boost leak but TBH you might as well have Stevie Wonder diagnose it. Trying to fix something via a video is never going to work.
    I assume that you don't have access to VCDS, which is the first place to go. Scan the ECU for faults.
    If you can't do that, then check ALL the boost pipes and joints out from the turbo outlet to the throttle body. Also check the diverter valve, especially if it's a std Audi one.
    I'd also consider looking at the sparkplugs. I don't thing the coilpacks are the problem at this stage.
    May 2015
    Hey Gavin
    here's some more info
    Address 01: Engine Labels: 06A-906-032-BAM.lbl
    Part No: 8N0 906 018 BJ
    Component: 1.8L R4/5VT G 0001
    Coding: 26710
    Shop #: WSC 79668
    VCID: 7AF1DAA466CBB4F120B-5122
    WAUZZZ8L721015623 AUZ7Z0A1912667
    4 Faults Found:
    16891 - Idle Control System RPM
    P0507 - 35-10 - Higher than Expected. - Intermittent
    16514 - Oxygen (Lambda) Sensor B1 S1
    P0130 - 35-00 - Malfunction in Circuit
    16684 - Random/Multiple Cylinder Misfire Detected
    P0300 - 35-00 -
    16685 - Cylinder 1
    P0301 - 35-00 - Misfire Detected
    Readiness: 0010 0101
    Previous to this lambda B1 S1 reading as open circuit so that's been replaced but still annoying it's coming up with malfunction in circuit.
    Got a forge008 coming so hopefully that'll help as you are correct - original Audi one is in.
    ESP light is now fixed - i had to do the basic setting, steering wheel to the left, right etc then it went away *victory*
    Hey Gavin
    Coding: 26710
    Shop #: WSC 79668
    4 Faults Found:
    P0300 - 35-00 -
    16685 - Cylinder 1
    Move this coil pack to #4 and see if the code moves with it.
    P0300 - 35-00 -
    16685 - Cylinder 1
    Nov 2014
    Sounds like what's happening to mine. ended up being about 5 very small air leaks all over.
    Get it smoke tested or coil packs too but do what gave said and move them around first as there is no point in buying a new set and wasting the money if that's not the issue
    Ps it's a BAM, take it into audi there was a coilpack recall a loooong time ago now, but if you missed it they'll still honour it...well they did for me at least.
    Audi S3 8L BAM 225 Custom Code Stage 2 — Gone but not forgotten
    Skoda Octavia RS 5E manual wagon
    May 2015
    so tightening up the hoses... are there some hidden ones that i should be particularly concerned with? i'm guessing i can just go from DV and follow all the hoses that connect to it on both big ends right?
    thanks for the advice on coil packs. will test & investigate further!
    Just crank them all up. There's plenty that are hard to get to.
    May 2015
    So i went to check out the coil packs and when removing coil pack #1 i found that the base had oil on it!??!? taking out the spark plug also revealed some oil...
    so it was only where the two meet but was dry on the actual tip. just a bit black
    so could this be why it was misfiring? and is this a bad sign???
    will be changing all coils and plugs soon anyway but it seems after going for a quick drive there is still hesitation and a quick VCDS scan revealed that the coil errors had gone (although i'm not sure if i drove around long enough for it to have logged anything...) will take a longer drive tonight and see what happens
    Attached Thumbnails Attached Thumbnails S3 1.8t boost problem / should apply to other 1.8t VAG motors-img_2660-jpg
    Dec 2007
    Melburg East VIC
    looks like the inner valve cover gasket is leaking
    just make sure you replace that before coils and plugs and you should be all good
    1.8T AGU | K04 | GIAC | 380cc | VR6 MAF | Custom Intake | FMIC | TIP | 3bar FPR | N75J | 42DD 3-2.5" TB | GFB DV | FK Highsport | ECS Stage 1 Clutch | OZ FUTURA
    May 2015
    No need to change the main one from removal of the cover?
