Hi Folks,
Thought I would post a bit of a thread about my Audi 80 Cab
In the random factory colour Aqua Metallic 1994 there plenty of little things to fix but overall in pretty good nic for 25 years old everything works or leaks lol.
Righto the low down 10/94 build two owners 109,XXX service history and the photos hide alot of sins, nice colour though! The car was absolutely filthy when i picked her/him up. Power steering pump leaking, needs new tyres, oil leaks, needs CV's boots, timing belt need, various trims pieces need replacing, front windscreen cracked, rear window in the soft top needs replacing and and some retrimming too arrrr the list goes on. Despite all that it drivers lovely and everything works, well the speedo cuts out every now and then.
Ive also started to gather a few bits and bobs for it
mk3 golf gti recaros, little test fit looks good now to sort some rails
The PITA with these thing is 4 x 108 wheels i found a set of nissan silvia wheels with enough meat to redrill so they are at the painters being refinished, will need to run some spaces to fill the arches and clear the suspension
Pete
