Bought this car in 2009 after owning a toyota soarer for one month and a civic for two months
originallycame with some cheap looking angel eye headlights, LED rear lights and TT 17" wheels.
Since then
Revo stage 1
Dyno'd 117kw atw
Engine
-Mahle Motorsport pistons - INA SPEC 82.5mm
-DM Forged H-Beam Connecting Rods - 144/20mm
-ARP Headstuds
-ARP head bolts
-ARP crank bolt
-Calico Coated Connecting Rod and Main Bearing Kit
-INA Engineering Master Gasket Set
-INA Fluidampr
-INA TFSI coilpack with adapters
Turbo Setup
-Frankenturbo F23 Hybrid K04
-Frankenturbo Exhaust Manifold
Cooling
-Wellycooler intercooler with 2.5" piping
-Mocal 8 row oil cooler with sandwich plate and thermostat
-BM sport gearbox cooler
Fueling and Intake
-044 Bosch fuel pump
-034 Motorsport surge fuel tank
-Bosch 440cc injectors
-3" MAF
Exhaust
3" stainless steel downpipe
High Flow Cat
2.5" cat-back with quad exhaust outlet - custom
Chassis
-ECS Polyurethane Dog-bone Mount
-Quaife Limited Slip Differential
Suspension
-Weitec HICON Gt coilovers
-H'n'R Front and Rear sway bar f-22mm,r-25mm
Wheels
-19x8.5 et35 BBS CH reps
Electronics
-Pioneer 7" Single Din DVD
-Cadence 12" sub
-NewSouth Performance boost guage
-AEM AFR guage
Braking
-Porsche Boxster Caliper
-312mm rotors
-Brembo pads
-HEL Stainless Steel Brake Lines
Cosmetics
-Facelift Headlights
-LED brake lights
Wish List
-RS4 Flat bottom steering wheel, in alcantra
-Recaro bucket seats
-water and meth injection
-roll cage
-strip interior
looking good mate, it'll be interesting to see how the f23 goes, how far away are you from install?
Probably a month or two away, the block needs to be bored and balanced and the mechanic is making a custom twin intake
going with f23 in the end! looking good, watching with interest!
Is it custom DNA tune for the AGU? Do you know what size maf you're going with?
Can't imagine it'll be the stock size maf since they max out at around 187 g/sec.
maybe try VR6 maf, AGU element is a straight plug in.
I'm looking into going BT as soon as i finish the house, I'll see how you go with this tune but I'll either go with this or Unitrinic BT440 tune & gt28. Good luck with the build, all the best!
1.8T AGU | K04 | GIAC | 380cc | VR6 MAF | Custom Intake | FMIC | TIP | 3bar FPR | N75J | 42DD 3-2.5" TB | GFB DV | FK Highsport | ECS Stage 1 Clutch | OZ FUTURA
Made some progress
Engine out
Head mechanic Paul made a sweet table with wheels to make working on the engine easier
Nice one! Can't wait to work on this thing.
VWWC Members - 2018 Special - ECU & DSG Remaps
DNA Tuning Australia - Enquiries: info@dnatuning.com.au
