Results 1 to 10 of 10
Thread: horn problem..
    Jun 2007
    Eastern Suburbs Melbourne
    horn problem..
    Hi guys. Wanting a bit of help please. Car is an 85 80 (sport )
    This used to be an intermittent problem but now it's happening more and more.
    Whenever I turn right, the horn beeps, and quite often when I hit the indicator (to turn right) the horn will be too.
    This is really starting to annoy me? Any one got any ideas? (besides just disconnect the horn)
    Thanks guys.
    Jarred
    i like volkswagens
    Horn Problem
    i think there is a cream you can get for that....
    Audi A4 Avant '99 1.8TQ, Chipped, Sports Exhaust, Eibach Springs, Bilstein B8, 18" RS4 Rims, S-Line Steering Wheel.
    Jun 2007
    Thanks guys.
    Jarred
    Sorry Jarred, couldn't resist.........only turn left.....
    George
    06 Jetta 2.0TFSI Killed by a Lexus!
    09 Eos 2.0TSI DSG Loved this car but has now gone to a new home!!
    14 EOS 2.0 TSI has arrived!
    Aug 2007
    Mate the horm works on an earth return so something is a miss in the horn pad or the contact ring on the indicator stock.
    Take the wheel off (24mm nut) . The contact on the stock switch behind the wheel isnt sitting on the steering wheel properly by the sounds. Have you had the wheel off??????
    JMac
    Alba European
    Jun 2007
    Nope havn't had the wheel off.
    I was hoping I wouldn't have too, (cause I hadn't done it before) but looks like I might have too. Will look over the weekend.
    Thanks Jmac
    i like volkswagens
    Aug 2007
    Hey mate its easy just tug off the horn pad and then its the 24mm nut, no worries
    Jmac
    Alba European
    Jun 2007
    took my wheel off today (finally) and then put it back on basically..
    I had a look at a few things, but wasn't to know wether it was meant to be or not, so I cut my losses and chucked the wheel back on.
    Took it for a quick drive round the block, and nothing beeped when it shouldn't have.
    So who knows. I'll write again if I have any more issues with it.
    (would post a pic, but I got a new camera, which is having issues with my PC!)
    i like volkswagens
    Aug 2007
    Ok then mate that sounds like its the contact on the switches and you have upset them a bit on removal/refit, all good if it has stopped mate. You would have seen this when you removed the wheel
    Jmac
    Alba European
    Dec 2007
    Brisbane, Southside...
    Quote Originally Posted by Jmac View Post
    Jmac
    On my old Magna the contact patches which Jimmy has alluded to had bent and under certain conditions they were touching even though I wasn't pressing on the horn.
    Was most embarassing as one day the horn just stuck on. I pulled the fuse until I worked out what the problem was. Basically all I had to do was bend the contact in question away slightly and all was good.
    Have you bashed the horn recently at someone nice and hard and given your windscreen a spray?
    2010 Renault Clio RenaultSPORT 200 Cup 20th Anniversary Edition - #19 of 30 - The French Connection...
    2004 Volkswagen Golf R32 MkIV - #044 of 200 - Gone But Not Forgotten...
    "Racing is life; Anything that happens before or after is just waiting." - Steve McQueen -=-=- "Si Vis Pacem, Para Bellum" - Unknown
    Aug 2007
    Yeah Trent good point there mate a good thumo on that pad can cause this too
    Alba European
