Results 1 to 10 of 11
Thread: Help from the resident master-techs to get the S2 running please :)
    Jan 2008
    Melbun
    as most of you know i now own an Audi S2 with the 5cyl 20vt ABY engine. i bought it from an auction damaged and it was probably sitting around for months without being started. so now it doesnt start. it cranks over but doesnt fire up.
    where should i start looking? i at first thought the coilpacks but even if one or two of them are dead it should still run? but yeah... no clue about these engines so somewhere to start would be great if Jmac or Seb or Matt or anyone who is clued up could give me some pointers
    cheers much appreciated.
    2x Caddy, 1x Ducato
    Aug 2007
    Yep mate ok when the engine is cranking is the fuel pump buzzing??????? Check in the plenum chamber , this is where the fuse box is. The cover will give you a description where the relays are if you get stuck i will give you the location, just im at he mother in laws at the mo , will be in later. Remove a plug check for a spark. Does it sound like it has compression?????? What kind of hit did it have?????? No damage to timing belt cover????????? Remember man start at the absolute basics. Good battery, check for spark, check the pump buzzing , if it is crack a line and see if you are getting juice. Fuel air and spark at the right time and that baby will go. Fuel pump relay also gets an earth pulse from the ecu, you can trick this too if need be but like i say BASIC 1st, then we will dig. Ah yes and a compression test - remove the fuse for the ecu. Might just need some oil down the bores mate , gassed up plugs and crap fuel the bores might have a wash.
    Chime if any dramas
    Jmac
    Alba European
    gpk_gti Guest
    did you end up starting the s2????
    Oct 2006
    sydney
    i have some time off work so hit me a pm and il come past and have a look at it for you if you like.
    Jan 2008
    Melbun
    not yet guys sorry i know i'm hopeless. thanks william i will take you up on that
    2x Caddy, 1x Ducato
    Rosebery Sydney
    Is your S2 running now?
    Hey,
    just following up on this as there has been no posts in a while and really interested to know if you got your S2 running.
    Cheers.
    Nov 2008
    Sydney, Macquarie Park
    he is too lazy ey, misch? start working on your s2
    '01 VW Bora V6 4motion - gone
    17x8 TSW Hockenheims ~ TyrolSport Brake Upgrade ~ SMF + Stage 1 Clutch ~ 42DD Shifter Linkages ~ FK Coilovers
    Feb 2008
    Yeah...What ever happened to "...Ill have her repaired and running for Nats..."???
    Aug 2007
    He,s waiting for me to get it goin for him when im in Sydney shame im only down for the weekend otherwise i would have it needs to come up here to me Mish
    Jmac
    Alba European
    Nov 2008
    heh, he keeps finding new excuses
