Results 1 to 10 of 12
Thread: Expensive repairs (Yes/No)?
Threaded View
  1. #10
    Rosebery Sydney
    One Step forward 2 steps backwards...
    Latest on the 200 Turbo:
    Car was in with mechanic getting second stage of work done:
    Brake bomb replaced - Now working as should.
    Warm up regulator recon - Part was not recond but replaced with old part and did not repair the problem with hard starting. Car is still tough to start and there is no holding pressure in the fuel system. I think replacing the accumulator or fuel check valve will do it.
    However now a belt which was replaced in stage one is making a horrible noise on start up.
    Rear springs replaced - The car is now sitting 2 or 3 inches taller on the right hand side then on the left. It seems like the rear suspension was just swapped around so the problem I have on one side is now on the other.
    Power steering rack recon - Ok this is done and I have the wheel alighment done too.
    Total cost $1740.
