chip it![]()
Just picked up an 00' A4T, Manuel, 150k, black, tan leather, 1 owner for $7k with 12 months rego.
Already installed a k/n pod and looking for other easy mods to give i a bit more oomf. Boost up maybe??
Anyway, any help and advice is greatly appreciated.
Mikk
chip it![]()
buy a manuel boost controller for $80 and keep winding it up til 1st and 2nd gears keep spinning
Be warned that the k&n may stuff up the maf sensor due to it being oil based.
I don't know about MBCs, these cars tend to run lean and cause damage when you try that. Maybe up 1-2psi, but probably not worth it.
APR or GIAC are the main 2 choices as far as chips go, around $1400 for GIAC and a little more for APR. It's definitly the best bang for buck. Seb in Girraween for GIAC and derek in Mona Vale for APR are the closest two to you I think.
Was: A4 B5 1.8TQ GP - K04, FMIC ,S3 injectors - Sadly gone
Now: 90 quattro RED - turbo project in progress
Triumph TT600 yellow
A boost controller isn't the way to go. The cost of getting it wrong would be far more than having the ECU done properly.
will a manual boost controller increase the fuelling??
is the a4 a quattro, because if it is, it already has a larger turbo..? (someone correct me?)
a chip/front mount IC/exhaust system/lighter wheels will make you go faster.. just depends on much monies you want to part with..![]()
87' MK2 GTI
13' MK7 TDI
80,000km 1997 MK3 VR6 manual for sale - www.vwwatercooled.org.au/forums/f23/80-000km-1997-manual-vr6-nsw-sydney-67658.html
No, a MBC just reduces the air going to the wastegate, so the wastegate may only see 10PSI while the intake manifold has 15PSI. It doesn't do anything to the amout of fuel. Some cars ECUs will increase the amount of fuel accordingly, but not audis and VWs.
I don't think he has a quattro, but all B5 1.8T come with the normal K03, the GP quattro versions (99-01) did have a different tune with 20KW more, but still the same hardware.
