It's looks like a don't care much for the S3 as I don't post anything about it from 1 year to the next. TBH it doesn't get used loads, except if the Polo is on blocks. I did run it down to Falls Creek and back at the start of March. 1600km each way. Set off Thursday, arrived Friday tea time. Lazy Saturday, 235km on the pushy Sunday. Drive home again Monday 7AM.
All the prep I did was blow up the tyres and check the oil. I did a brake fluid replacement around Christmas time, so knew the fluid was full.
Filled it with 98 and set off. It ran like a top in both direction, averaged 7.8l/100.
It's such a reliable car usually, it even rolled over 300000km on the way home.
The service light came up a week after getting back so I did the oil and it has been dropping a bit from the sump plug. I swapped the washer yesterday, same deal this morning. Another puddle. It had felt a bit odd when I did it up. So I just leapt in a pulled the sump off. Got a few spare on hand so chucked another on.
Gutted to spot after I got the "bad" one off.
The plug is shagged. Probably 8-9 years old and ECS have changed the design slightly to make the flange thicker. So I am willing to bet I am not the first to have this happen.
Anyway, it's now got a wrinkle black sump and a new sump plug fitted.
I also polished the headlights again, they yellow up really quick with it living outside, only take a couple of minutes though so no big deal. Autosol, and some Meguiars.
- You may not post replies
- You may not edit your posts
Forum Rules
