Page 5 of 5 FirstFirst ... 345
Results 41 to 47 of 47
Thread: THE brake story...continued...HELP!
    imported_brackie Guest
    Valve
    Nope...It's 100%
    Camden, Sydney
    How did you test the one way valve?
    What about the brake bias valve under the back axle?
    Valve.
    Quote Originally Posted by Golf Loon
    Removed it and blew/sucked both ways. It holds.
    Works as far as I can tell. When the brakes were pressure bled in the workshop he did it "on the level". Anyway, how could it be involved? I know what they do but I don't know enough about how they work. Do you agree with my logic about the booster?
    Camden, Sydney
    Yes I agree about the booster, but remember what the Haynes manual says.."never omitt any part from your troubleshooting even if you know it to be good"
    Where else can air come into the system guys if the booster is ok?
    Took out the valve altogether and plumbed direct. For some reason Audi has a complex vacuum takeoff from 3 points on he intake side. The valve itself is actually mounted on a "T" and only operates on 1 of the 3 hoses that go to the manifold Duh... Should have taken a pic. But anyway, it made no difference so I put it back.
    Apr 2006
    Melbourne, Victoria
    Hi brackie,
    have you sorted out the braking problem yet? I hope so. If not, there was something in the thread that caught my attention. You mentioned that the old MC was 12mm and the new one 9mm. If you are using the same booster on both MC's then then there could be a problem. The smaller diameter MC displaces less fluid per unit of distance travelled but can generate higher pressures in the braking line per unit of force applied to the pedal. As the booster is applying extra force to supplement the muscles in you leg, it may be applying enough force to cause the smaller diameter mc to travel further.
    If you have a 9mm mc then you may not need the vacuum assistance at all as you now can generate higher brake line pressures for a given pedal effort, the trade off being longer travel.
    On the subject of brakes, i have several GLD's that are being prepared for roadworthy. I have measured the discs and i have thicknesses of 7-8mm. this seems to be very thin. Do you know what the wear limits are for the GLD's? Also, if i go to a wrecker, are there any other cars with better fromt brakes that i could adapt to the Golf?
    Thanks
    Matt
    Beige 79 Mk1 GLD White 76 Mk1 LS 3 door
    White 68 Alfa 1750 Berlina Champagne 91 Alfa 75
    Red 09 9N3 Polo TDI White 2010 Skoda Octavia Combi TDI
    Diesel brakes
    Quote Originally Posted by hiho
    Hi brackie,
    It came good! I gave the car to our dairy hand and she's been driving it without mishap (apart from a duff water pump) for a few months. Can only assume that there was air trapped in some obscure place and it vented itself
    Good stuff! Yeah, your logic is good and this sort of info is good to have on our database. I still have the larger master cylinder re-sealed and in good order.
    No, but I'll bet that someone on the forums does!
    Look in "Interesting Articles" for the posts on
    Hi brackie,
    It came good! I gave the car to our dairy hand and she's been driving it without misshap (apart from a duff water pump) for a few months. Can only assume that there was air trapped in some obscure place and it vented itself
    Look in "Intersting Articles" for the posts on
    Hi brackie,
    Look in "Intersting Articles" for the posts on Commodore/Magna conversions. I believe that Camira brakes can also be adapted. If your Mk1 diesel appears to have poor brakes check the vacuum pump. The diaphragms may be perforated (especially if you have excessive blow-by.)
Similar Threads
  1. brake light keeps coming on ????
    By mean_green_mk1 in forum Mk1 Golf
    Last Post: 12-03-2007, 09:26 AM
  2. Brake reservoir lid
    By gman in forum Mk3 Golf & Vento
    Last Post: 14-01-2007, 01:05 PM
  3. Dusty Brake Pads
    By shaneth in forum Polo (9N & 9N3, 2002 - 2009)
    Last Post: 01-01-2007, 09:28 PM
  4. Golf Mk1 brake confusion
    By tassie_euro_mk1 in forum Mk1 Golf
    Last Post: 21-07-2006, 05:47 PM
  5. A brake story...
    By imported_brackie in forum The Audi Quarter
    Last Post: 23-05-2005, 10:20 AM
