Results 1 to 10 of 17
Thread: Audi TT 1.8t
    Feb 2015
    ACT
    Audi TT 1.8t
    Hi everyone,
    Just wondering if theres any good info about getting some tuning on my 1.8T. I'm racing it in my local Canberra Hillclimb, currently hooked up with a GFB Electronic Boost controller and its absolutely horrible. I'm running 8PSI at the moment and if i turn up some more it sounds like its prematurely letting off the boost. I've done some boost leak testing and im 80% certain its not that. Ive got the AUM 110kw of the 1.8T (Bad choice but im trying to change that now)
    I went to go look at a APR tune but of course they decided to have a legal battle as of late.
    Any information and tuning advice is much appreciated. Are there any other companies around?
    So far ive got TIP, K04001 Turbo, GFB electronic boost controller, Aftermarket DV, Full delete -(SIA, N624, N75, SAI, EVAP all deleted)- Coilovers, catch can, rear weight removal, Full Turbo back exhaust (with 3" dump, 100 cell cat down to 2.5" out to the back). All the work I've done myself exhaust the exhaust.
    Thank you
    Jan 2008
    Sunshine Coast
    With a car that modified you would be wise to tune it on a local dyno. An off the shelf tune is going to assume you have things like the N75 system in-place. Personally I'd be scared to remote tune your car outside the live service, in real time on a dyno.
    May 2015
    Good work on doing all the DIY stuff
    You really need to get the n75 back on there as yes... you've already seen that the EBC is a piece of ****e on this machine.
    The ECU will be seeing all sorts of incorrect info without the N75 system in place hence your running problems.
    Also with all the other sensors deleted, have you made the necessary software changes so the ECU isn't searching for them? Otherwise you will be throwing CEL's galore which then could be contributing to the bad running of the car.
    If you're in Canberra why don't you visit Ed in Sydney or get in touch w/ Gavin who is on this forum too. He'll be able to help with 1.8t tuning for sure but you'll have to send your ECU up to him.
    Quote Originally Posted by IanPGonzaga View Post
    Unfortunately, you have gone about this completely backwards. You should be buying a lottery ticket though as the motor hasn't blown yet!!
    As mentioned you need N75 putting back on the car. Then sell the EBC to someone who is into JDM.
    To run that K04 you need a 3 inch MAF housing, a better fuel pump and bigger injectors.
    APR couldn't help you with a tune for it as it stands anyway.
    I wouldn't want to get involved either, without being able to get hands on with the car. I seriously recommend that you don't put the boot in until you have it tuned properly.
    Happy to give advice, just ask the right questions.
    Jul 2005
    Now is probably the best time to put in a stand alone ecu and be able to tune it to your requirements and future mods.
    Widebody Cayman S Turbo, 83 ur Quattro
    2000 996 C4 cab,12 Scirocco R OEM+ STG2+
    72 914 (3.2S boxster pwr), 92 G60 Corrado
    76 Scirocco(TFSI and DSG) 2018 Tiguan,Eureka,81 924.
    There's no need to go standalone and lose all the factory features. I'll concede there isn't someone on every street corner that can tune the ME7 ECU but this is far from exotic enough to need thousands spending on it.
    Feb 2015
    ACT
    Thanks everyone for the input. I should have posted a year ago.
    Apologies for being unclear. I would re-attach the n75, n249, back to the engine to allow for the ECU to control the car once i got a tune. Yes, I will definitely be selling the EBC, even though i have to say, i do enjoy this GFB version.
    I did own a mk4 golf 1.8t in the past that ive had tuned before by APR. I got a stage 1 i beleive and i enjoyed the extra gains, but i would like to go a little further with my TT (what modder has never said that before )
    The K04001 isnt like the larger K04 found on the 225 (ko4022?) i beleive, its only slightly bigger and ive read it does run ok on a stock 1.8t tune (obviously without gains until tuned further). I agree i will need to find some bigger injectors and a 3" MAF.
    I have looked at the Franken Turbo website from the states. The prices there look quite affordable, yet i know affordability doesnt ensure quality. Take my old $300 3" Turbo back exhaust from ebay for example
    I suppose i am trying to aim around the 150kw+ mark to be able to foot it at my local motorsports. I would rather lighten up my car and improve the handling and more so braking before i go any further than 180+.
    I was thinking a trip up to Sydney may be my best bet for tuning options. Does anyone know how i can contact Ed? or any reliable places, google is great but first hand encounters are more reliable.
    Again, your help is fantastic. Beers all round
    Jan 2008
    Sunshine Coast
    Parso Rex - Mark at Recode in Sydney would be the guy I know to handle a custom tune in real time on a dyno, but expect to be told to repair some of the factory systems or pay a bit to tune all those deletions out properly.
    May 2015
    Home
    = Ed
    Have fun with it once it happens!
    Quote Originally Posted by volkieboy View Post
    Peregian Beach
    !50+kw shouldn't be too hard. I reckon you can get close to that on a Polo GTI with standard injectors and standard turbo with a stage 2 tune, downpipe zorst etc.
