Results 1 to 4 of 4
Thread: Help A3 1.8T
    Jun 2009
    Melbourne, Vic
    Question Help A3 1.8T
    Going to look at an Audi A3 1.8t 2002 tomorrow.
    Any special things that I should look for?
    High KM's and low price.
    Thanks,
    Old Enough to Know Better.
    2013 Jetta tdi
    1998 Porsche Boxster
    May 2015
    check out the usual oil leaks from the top looking into the engine bay and the bottom where the oil sump is
    visually inspect the turbo area for oil too
    check all electrics work, windows wind properly, check for rust, bubbled paintwork
    ideally you wanna start the car up cold to see if there's any trouble with the fuel pump. otherwise check for steady idle (if it's not steady it could mean a vacuum air leak). listen out for any other sucking noises on idle and check there are no rattling noises.
    check the oil and under the oil filler cap - you just want it to be oily looking, no froth
    driving the car should feel the turbo kicking in, no hesitation or power that seems like it's being held back. that may mean coil packs / spark plugs need replacing. listen out for any knocks or clunks when turning, braking, over bumps.
    good luck hope it turns out to be the car you are looking for!
    Jul 2012
    Sinagra, Western Australia
    And a good service history using good oil if you have access to the invoices. Crap oil loves to cook in those things.
    Volks Handy
    Servicing - Repairs - Diagnostics - Mobile fault scanning/clearing - A/c work
    10 years experience working for Audi/VW/Skoda
    Now in Perth NOR, Western Australia.
    Jun 2009
    Melbourne, Vic
    none of the issues that you outlined so was purchased. Gear selection issue though and have put down to slave cylinder or clutch but for the price it's worth it.
    Thanks for all your help.
    2013 Jetta tdi
