Little update - the original stage 1 tune + EGR coding out I got from UGP for the SQ5 was a fail and messed with the DPF signals which after several thousand km's (and no DPF regen) eventually put the car into limp mode.
I was worried about the lack of regen because my car religiously does a regen every 500-600km's, and the screenshot below shows it had not done a regen for 2,251km yet it was only registering that the DPF was 38% full.
Then the errors started happening - turbo underboost error, ECM error etc.
Thankfully Alex from UGP express posted me up a CMD flash device allowing me to put the car back to the stock tune.
With the car now back on its stock tune, my VAGDPF app was reporting that the DPF was 588% full.....fun times. This was all happening just a few days before Christmas, so with no ability to get into my mechanic - we parked up the car and let it sit in the garage over the Christmas/New Year period. Borrowed a Diahatsu Terios from a friend to get around in for a few days - wow cars have come a long way in 15 years.
After doing some research and investigation, I decided to try and flush out the DPF with some chemical cleaners and high pressure water and see if I could fix the issue myself. Thankfully the twin DPF setup on the SQ5 is super easy to access and remove, only taking probably 10-15mins to remove.
The DPF was well and truly blocked visually. I sprayed it with some carby cleaner and some degreaser, let it soak for a while and then blasted it for a good 10-15 mins with the Gerni. Heaps and heaps of black muck came out, but it was clean as a whistle afterwards. It was hot as hell that day, so I let the DPF's sit out in the sun for a few hours to try and evaporate as much of the water that was in the filters before refitting it to the car.
Good news, after refitting the DPF's my VAGDPF app reported that the filter was clean, but the car was still in limp mode...so I had to perform the procedure shown in the link below to reset the DPF parameters. More good news, the car was now out of limp mode and back to have 230kw/650nm like it should.
VW T5.1 DPF related Values obscure
I kept the car on the stock tune for about 8-10 days to make sure everything was ok and that the DPF went back to doing its regens as required which it did - success!! After I was satisfied the car was back to "normal behaviour" again, I used the same CMD flash device that UGP had sent me to flash the car with a normal Stage 1 tune (no fancy EGR deletes or anything) and took the car for a spin. Improved throttle response and more torque was immediately apparent, even better than the "original" stage 1 tune.
So this was early January by the time all of this was sorted, and the car has been running perfectly since - hopefully it stays that way.
