Page 1 of 44 12311 ... LastLast
Results 1 to 10 of 436
Thread: Audi S3 8P3 CustomCode Stage 2 PSS
    brisbane
    the girlfriend finally admitted defeat to not being able to handle the clutch on the a3, therefore I was 'forced' in to buying this. she actually wanted an automatic but... well... tough luck...
    and the current list of mods, i'm keeping this updated as i go...
    Engine:
    2.0 TFSI Performance Turbocharger TTE420+
    APR TTE420+ Turbocharger ECU Upgrade
    Blue Flame Audi S3 Quattro 2.0 TFSi (Full 76mm System) 100 Cell Hi-Flow Cat
    Evolution Motorsport 2.0T FSI V-Flow Intake
    SPULEN Intake Manifold Runner Flap Delete Kit (SE-001)
    HPA Motorsports HPFP High Pressure Fuel Pump (HVA-270)
    ECS Fuel Pump Cam Follower Replacement Kit (06D109309CKT)
    Airtec Intercooler Upgrade for VAG 2.0 Petrol TFSI Including Black Hoses
    BSH FSI Integrated Throttle Pipe Including Black Hoses(30306054)
    Neuspeed HI-FLO K04 Turbo Discharge Including Black Hoses (48.02.69)
    GFP DV+ Diverter Valve (T9351)
    Torque Solution Billet Engine and Transmission Mount - 2.0T (TS-VW-012)
    APR Pendulum Mount (MS100106)
    SPULEN Engineering Dog Bone Engine Mount (SE-70116)
    SPULEN Dog Bone Engine Mount Insert Kit - Street (SE-70117)
    Forge Motorsport Catch Can and PSV Delete with Boost Tap (FMMK5CTC)
    OEM Audi TTRS Engine Cover (06F 103 925J)
    OEM Audi Engine Cover Fitting Bolts (2x WHT000731A & 1x 06E103164E)
    OEM Audi TTRS Low Pressure Fuel Pump (8J0919051E)
    OEM Audi G410 Low Pressure Fuel Pressure Sensor (06E906051K)
    OEM Audi Fuel Filter (1K0201051K)
    Torqbyte PM3 - High Power LPFP Driver with VAG Plug and Play Wiring
    Tarmac Engineering 2.0 FSI High Pressure Rail Valve (155 Bar)
    Tarmac Engineering Water/Meth Throttle Body Spacer
    AEM V2 1-Gallon Water/Methanol Injection Kit with Internal MAP Sensor (30-3300) – not fitted
    AEM Water/Methanol Injection Filter (30-3003) – not fitted
    MAC 3 Port Boost Control Solenoid (35A-AAA-DDBA-1BA) – not fitted
    Devils Own Water/Methanol Injection dual Nozzle Upgrade (2500) - not fitted
    Devils Own Water/Methanol Injection Self Filtering Tank Tap (3019) - not fitted
    Devils Own Water/Methanol Injection Check Valve (3031) – not fitted
    Forge Expansion Bottle Cap and Oil Filler Cap (FMCAPS2-BLK)
    Forge Silicone Carbon Canister Black Hose Kit (FMCCHMK5)
    Forge Silicone Coolant Black Hose Kit (FMKC010)
    Forge Carbon Canister Cover Black (FMCHSCI)
    Forge DV to Intake return Black Hose (FMRLH - 2L)
    SPULEN 2.0T FSI Silicone Breather Black Hose (SE-022BLK)
    SPULEN Brake Booster Black Hose Kit (SE-041)
    ECS Billet Aluminium Oil Filter Housing – Silver Anodised (ES#2723776) - not fitted
    ECS Magnetic Sump Plug With 10 Copper Washers (ES#2804343)
    PSI Tuning Aluminium Dipstick - 2.0TFSI (14100)
    Transmission:
    South Bend Stage 3 Daily Clutch and Flywheel Kit (KFSIF-SS-O)
    USP Stainless Steel Clutch Line - Audi/VW 6spd for RHD Vehicles (USP-004-78 )
    Fluidampr Engine Damper 2.0TFSI (551211)
    Forge Big Gear Knob Matte with Audi S3 Insert (FMBK)
    Forge Adjustable Quick Shifter for VAG 6 Speed Models (FMVWQS)
    Forge VAG 6 Speed Side Quick Shift (FMVWSQS)
    42 Draft Designs VW Shifter Bushing Set (42-455-007)
    Verdict Motorsports Shift Bracket Bushings (VMS100)
    Suspension:
    Haldex Performance Upgrade Gen 4 - 0BR Couplings Audi S3
    Haldex Wireless Remote Control - Suits Gen 2 and Gen 4
    VWR StreetSport Coilover Suspension Kit (R32xxxx)
    VWR Adjustable Front Drop Links (PA016A)
    Torque Solution Billet Subframe Bushing Insert Kit - (TS-AUDI-007-A3)
    Whiteline Front Sway bar - 24mm X heavy duty blade adjustable (BWF20XZ)
    Whiteline Rear Sway bar - 24mm X heavy duty blade adjustable (BWR21XZ)
    Whiteline Control Arm - Lower Inner Rear Bushing - Anti-Lift/Caster Correction (KCA316)
    SuperPro Roll Centre Adjusting Ball Joint (TRC0003)
    Brakes:
    OEM Audi TTRS Front Brake Callipers (8J0615107A and 8J0615108A)
    OEM Audi TTRS Front Brake Discs (8J0615301F)
    OEM Audi TTRS Front Brake Pads (8J0698151K)
    RDA Dimpled and Slotted Rear Brake Discs (RDA7384D)
    Hawk Performance Ceramic Rear Brake Pad Set (HB544Z.628 )
    034 Motorsport Stainless Steel Braided Brake Lines for Audi TTRS (034-303-0011)
    TRW GP600 Dot 4 Racing Brake Fluid
    Wheels:
    Oettinger RE's 19x8.5 et50 5x112 Bolt Pattern
    Borbet Hub Centric Rings (57.1mm to 68.00mm)
    Goodyear Eagle F1 Asymmetric 235 35 19
    Interior:
    P3 Cars Integrated Vent Digital Gauge Audi 8P A3 (p3-vent-gauge-a3-tt-er)
    P3 Cars Integrated Vent Digital Gauge Analogue boost sensor (P3BST100)
    Dual OBD Port Connector (for P3 Gauge)
    ECS Interior LED Lighting Kit (PL3642BA9KT1)
    Bose Illuminated Speaker Grilles (CarStyle4you) – not fitted
    S3 Glove Box Illuminated Handle (CarStyle4you) – not fitted
    S3 Illuminated Dashboard Switches for WMI On/Off (CarStyle4you)
    Audi Rings Illuminated Dashboard Status Indicator for WMI (CarStyle4you)
    iPod Interface Alpine KCE-425i (IMA425I) – not fitted
    Kufatec IMA Multimedia Adapter "Plus" (35538 ) – not fitted
    Kufatec IMA - Harness - Audi RNS-E - "Basic"/"Basic-Plus" (35542) – not fitted
    Kufatec IMA Control Wire - Stereo Jack 3.5 - Version 2 (35552) – not fitted
    Kufatec Adapter - additional video Integration (35570) – not fitted
    Kufatec IMA - Harness - Rear View Camera Auto Switch - Audi RNS-E (35676) – not fitted
    Kufatec Complete set Rearview Camera Low Audi 8PA (39878 )
    Kufatec AMI Glove Box Storage for iPhone (37154)
    ViseeO Tune2air WMA1000 - Wireless Bluetooth Music Interface Adapter
    OEM Audi iPod Adapter (8E0051444)
    OEM Audi SDS “Speech Dialogue System” Upgrade
    OEM Audi Ash Tray Delete (8P0863301A4P)
    OEM Audi Business Card Holder (8P0941561J)
    OEM Universal Mobile Telephone Holder (4G0 051 435C)
    OEM Universal Mobile Telephone Cable for iPhone 6 (8V0 051 435E)
    OEM Microphone - BOSE Volume Fix (8E0 862 373A)
    OEM Audi Antenna Fix (000098652A / 000098692 / 8P4035225B / 8P4035225 / 1C0973119B / 000979009)
    OEM Audi Push Button Start (8E0863284E5PR / 8E0905217 / 8L0971883 / 000979009)
    OEM Audi Under Seat Storage Drawer (8P08815814PK)
    OEM Audi Cargo Net (8E5861869)
    OEM Audi Rear Power Socket (8E0919309 / 7L6919341F)
    Rear Cargo Boot Floor Rubber Liner
    Exterior:
    OEM Audi Black Edition Front Grille (8P0853651QVMZ)
    OEM Audi Black Edition Driving Light Grilles (8P0807681PZDE / 8P0807682GZDE)
    OEM Audi Black Edition B Pillar Covers (8P3853289DY9B / 8P3853290DY9B) – not fitted
    OEM Audi Black Edition B Pillar Cover Rivet Fixings (N0161857) – not fitted
    OEM Audi Front Number Plate Delete (8P0807287H) – not fitted
    OEM Audi MY11 Rear Light Clusters – (8P3945095C / 8P3945096C)
    LED Front Driving Lights
    LED Rear Number Plate Lights
    Front and Back Gloss Black Audi Rings
    Front and Back Gloss Black S3 Badges
    Laminex Smoked Protectors for Front Main Beam and Driving Lights – not fitted
    Gecleant Glass Rear Wiper Delete Plug
    Secure a Plate Rear Number Plate Holder - 372mm x 100mm (1053)
    Front Bonnet Lip Car Bra
    ECS Jack Adaptor Pad Kit (ECS10724KT)
    Feb 2009
    Please Enter Location
    it's a nice looking car!
    Jul 2009
    Melbourne, VIC
    Looks good - facelift 3 door is a rare sight!
    Sep 2012
    Brisbane, Northside
    awesome, shes a beast!
    Jun 2009
    Looks ace, just need to change the licence plate.
    brisbane
    Quote Originally Posted by reco View Post
    thanks mate, much appreciated. a few photos of the day it was collected from its previous owner....
    s3 spec provided at time of sale is as follows...
    Manufacture Date: 2010
    Registered Date: 11/03/2010
    Number of kilometres: 12800
    Number previous Owners: 1 (purchased from the Sales Manager at Audi Albury with 1900 kms on the clock)
    Factory Extras: Audi Exclusive Bucket Seats, Flat bottom Sports Leather Steering Wheel, Leather seats - Two tone, Metallic Paint, Audi Navigation System RNS-E,
    Non - Factory Extras: Tinted Windows, Alpine iPod/TV integration module, H&R Sport Springs for 8P S3
    Quote Originally Posted by Alister View Post
    yeah you dont see too many three doors, surprisingly i have seen a fair few more whore S3's recently in the area
    Quote Originally Posted by Turbo_8L View Post
    cheers dude, actually a bit disappointed (read a lot disappointed) with the performance compared to the a3. will eventually fix that though
    Quote Originally Posted by team_v View Post
    thanks, consider it done. will eventually have my plates on
    brisbane
    had a full machine polish and wax to remove those annoying swirl marks that show up on black paint. i took a couple of shots while i was waiting to pick the mrs up from work...
    i had it done at audi centre brisbane as it was still under warranty and if they stuffed it up they could fix it...
    Apr 2008
    Well done mate ... nice and clean audi...
    R36 > MK5 2006 1.9 TDI > MK4 2003 1.6 Generation > MK3 1995 2.8 VR6 > MK2 1990 1.6 > MK1 1982 1.8 GTI
    brisbane
    Quote Originally Posted by VW VR6 View Post
    thanks mate, appreciate your comments. looking to chnage things up a bit soon though, nothing drastic, just a bit more performance...
    Jun 2013
    Sunshine Coast, QLD
    Love this thing and love driving 8P S3's! They are a special and rapid machine. Congrats mate
