I did a bit of work over the weekend to prep the car for the btuned sprint series at lakeside on the 8th of feb. first up was the front drop links as they were making an awful racket...
YouTube
I didn't go with the pillow ball joints this time; they were replaced with some whiteline items that I measured up against my old units. I also stiffened up the rear sway to try and achieve more oversteer...
next was to replace the no. 7 spark plugs with no. 8 and closed the gap to 0.022" as per the APR TTE420 tune specification...
the clutch has always felt unusual to me and on doing some reading I thought it may be to do with the hydraulic clutch valve so I decided to remove it. I put a cloth down to catch any dripping fluid...
this is what it looked like removed from the car...
and then this was it with the valve removed...
then I decided to reduce the pedal travel by replacing the clutch stop; this is the old stop in place...
this is both clutch stops compared...
then the new one installed...
I finished off by bleeding the clutch and the brake lines; I want to give the M2's a run for their money on the 8th...
