Page 24 of 44 FirstFirst ... 14222324252634 ... LastLast
Results 231 to 240 of 436
Thread: Audi S3 8P3 CustomCode Stage 2 PSS
  1. #231
    brisbane
    as the weather has been so good lately i took my passenger chair for a sun bake…
    i'm trying to get all the little bits and pieces installed in the interior like i would have spec'd it from the factory...
    not the most exciting upgrade but matches the one on the drivers side now. first aid kit in one, umbrella in the other…
  2. #232
    brisbane
    while the chair was out i decided to whip out the centre console and install the push button start. firstly i wired up the button to the lighting circuit on the cigarette lighter and clothed taped it…
    i also hooked up the multi meter to check the button operated correctly as can been seen in the video below…
    lights on with the cigarette lighter closed…
    lights on with the cigarette lighter open…
  3. #233
    May 2012
    Nice work Ritch.
    Do you think you could get one of those in my GTI? Happy to pay
  4. #234
    brisbane
    Quote Originally Posted by grandturismo View Post
    Nice work Ritch.
    thanks Al, no problem installing one for you mate. i'd just have to make sure its the same set up as my car, flick me a photo of your centre console to see if the audi start button would work...
    no worries about cash mate, supply me a pint at the end of the job and i'll be happy enough...
  5. #235
    Nov 2014
    Been busy since the a3. This thing looks amazing. All the right mods. Really dig it!!!
  6. #236
    brisbane
    Quote Originally Posted by jgribben View Post
    thanks mate, i have few more little mods to come and one not so little mod...
  7. #237
    brisbane
    once i installed the 5mm spacers i thought i'd get the alignment checked to see if i could get any more camber out of the front. the suspension shop said its pretty well set up for road and occasional track use so i thought i'd leave it alone. he did slightly adjust the rear toe...
    once i got the car back home i gave the inside a quick clean after my recent rooting around installing stuff. not much more to do now; illuminated bose speaker grilles and s3 glove box handle, illuminated switch for water meth on/off and illluminated switch blank for status light, also toying with the idea of a gauge for water meth flow meter. not sure whether to install the gauge in a vent pod or replace the boost gauge on the steering cowl. i'm not really a fan of the cowl gauge at the moment as it doesn't look much like an oem install...
  8. #238
    brisbane
    my resistors showed up so i should be able to get rid of that horrible bulb out warning...
  9. #239
    brisbane
    i had a couple of days during my last break to do it a bit more to the s3, i finally got these made up to ensure my wheels clear the rs3 brakes. pretty hard to tell they are there i reckon...
    i then decided to tackle wiring up my push start as i only had time to install the switch last time. not many photos unfortunately, first requirement is to remove the steering wheel...
    a snap of the connection to the rear of the ignition barrel. for anyone planning to do the same mod the wires which require switching are the yellow and red ones...
    while i was in the mood and things were going well i decided to install the s3 and 4 rings switches which i will use for my w/m set up. s3 push button for on/off and the 4 rings for the wm status light...
    finally a quick vid of the push start in action...
    once it was all complete i gave the car a wash and wax before i took it for a run to the pub. i also wiped the engine bay down and was surprised how well it came up so i took a photo...
    a photo from the pub carpark...
    the hybrid arrived in the post yesterday so should hopefully see more power in the new year...
    and finally another shout out to my contact at audi for coming through with fuses i was chasing (a couple of fuses in the fusebox were a different type and my ocd couldn’t handle it) and he threw in an mmi cable for good measure, top man...
  10. #240
    brisbane
    nothing special but for some reason i like it. my mate grabbed his camera off the passenger seat to take a photo of the pub and i noticed the s3 in the shot when i was flicking through his photos. i wish he'd closed the door...
