Page 12 of 44 FirstFirst ... 2101112131422 ... LastLast
Results 111 to 120 of 436
Thread: Audi S3 8P3 CustomCode Stage 2 PSS
  1. #111
    brisbane
    Quote Originally Posted by guile View Post
    playing around with the plates today. so far i'm thinking the slimline plate is the cleaner option. what do you guys reckon...
    and this would be awesome...
  2. #112
    Slimline for sure.
  3. #113
    brisbane
    Slimline for sure.
    thanks mate, the slimline is staying for now...
  4. #114
    brisbane
    added a few more bits at the weekend. the dog bone mount upgrade is one of the easiest and cheapest mods i've done; would highly recommend to anyone. the bolt was bloody tight to back off though, like the length of my persuader...
    once greased up it was easy to slip in...
    installed and torqued to f king tight...
    surprised at the state of the original bolt, might explain why it was so tight...
    next on to the front brake pads, originals removed...
    new ones fully lubed up...
    and finally installed with a quick wipe down...
    ran out of time to do the rear brakes before heading to the newmarket meet. a couple of photos...
    and lastly...
  5. #115
    Jul 2013
    Plates look awesome!
    are you doing Happy laps on the 14th?
  6. #116
    brisbane
    Quote Originally Posted by 14nce View Post
    Can't make the 14th mate, out of town. Would be good to catch up at some point though and have a nosey at your 8l...
  7. #117
    brisbane
    The final piece of the puzzle showed up today, just hope they are as good as everyone reckons...
  8. #118
    brisbane
    got a few more bits fitted over the weekend…
    i took this shot for reference before i started…
    the destructions reckoned you can just pull the original linkage off the splines, yeah good luck. after a bit of vigorous tugging i nearly put my back out and gave myself a hernia at the same time. i then decided to make my own jack off screw, nothing rude, i just used a bolt to jack the linkage off the box…
    i also got the haldex on too. i didn't really want to cut the grommet in the boot floor but it appeared to be the best option and dropped the plug right in the location of the controller…
    all hooked up and the boot put back together. fits in pretty neat and looks fairly factory…
    and just so i can remember what controls what…
    also for future reference i decided i want to find out what all the option codes are if possible. should anyone know how to decipher the codes it would be much appreciated…
    finished off by giving the bike a clean, i'll be doing a bit more work on this now the s3 is finished (all except the coolant hoses to go one)…
  9. #119
    brisbane
    really no trick bits to the options list. service interval prolongation is a weird one though...
    E0A = No special edition
    7A1 = CD changer preparation
    4UE = Air bag for driver and front seat passenger
    6XD = Exterior mirrors: electrically adjustable/heated
    5SJ = Left exterior mirror: convex
    6TQ = Right exterior mirror: flat, large viewing field
    1KW = Disc brakes, rear
    J0L = Battery 340 A (70 Ah)
    1ZK = Disc brakes, front
    1AT = Electronic stabilization program (ESP)
    3FA = Without roof insert (standard roof)
    UB5 = Rear shock absorption for sports design
    G12 = Front shock absorption
    5TL = Decorative inserts in piano lacquer
    7X1 = Park distance control
    4R4 = Power windows with comfort operation andcircuit breaker
    F0A = No special purpose vehicle, standard equipment
    8GU = Alternator 140 A
    0YC = Weight range 3 installation control only, no requirement forecast
    L26 = Suspension range 26 installation control only, no requirement forecast
    TA2 = 4-cylinder gasoline engine 2.0 L unit 06F.D
    3NZ = Rear seat bench unsplit, backrest split folding
    8BP = Bi-functional headlight with gas discharge lamp
    U1A = Instrument insert with km/h speedometer,clock, tachometer and trip odometer
    X8C = National sales program Australia
    1N3 = Speed-related variable steering assist (Servotronic)
    2PF = Leather trimmed multi-function sports steering wheel
    8Q3 = Automatic headlight-range adjustment dynamic (self-adjusting while driving)
    9Q2 = Multi-function display/on-board computerwith check control
    8Z6 = Hot country
    D81 = 4-cyl. gasoline engine 2.0 l/188 kW 16V turbo FSI, homogeneous Base engine is TA2
    7Q0 = Without navigation device
    C8C = Alloy wheels 7.5J x 18
    7K0 = Without tire pressure warning light
    4X3 = Side air bag front with curtain air bag
    3L3 = Manual height adjustment for front seats
    4KC = Side and rear windows in heat-insulatingglass
    3Y6 = Sun screen for rear window
    4K4 = Radio remote controlled central locking
    5D1 = Carrier frequency 433.92 MHz-434.42 Mhz
    1SA = Without additional front underbody guard
    UG0 = Without hill hold control / hill descentcontrol / comfort driving assist
    7MG = Emission standard EU5
    QG1 = Service interval prolongation
    4GP = Windshield in heat-insulating glass withsunshield and viewing window for vehicleidentification number
  10. #120
    How does the new gear shifter feel? I see you also got the metal side to side arm which i believe is off the older (Mk4 era) cars, before they cheaped out and moved to plastic. I've been thinking about possibly getting another short shifter (i had the DieselGeek shifter before but hated it...so notchy) and didn't know whether to get NeuSpeed, HPA or Forge.
    I've currently got the 42DD solid linkage bushings which make a nice difference to the feel of the gears and reduced ALOT of the rubbery-ness of the stock shifter, and have just bought the Verdict Motorsports bushings that replace some of the bushings where the shift linkage bracket connects to the gearbox.
    And how do you like the Haldex upgrade? Have you had a chance to test it out yet?
