from the info i have i think the spec when i bought the car is as follows;
ENGINE + PERFORMANCE
- Custom FMIC setup
- Custom twintake
- Oettinger spec'd K04 turbo
- N75j Boost Solenoid
- Forge BOV
- Larger injectors
- Custom Intake Manifold
- Relocated TB
- Custom hardlines
- Custom Catch can
- CustomCode tune (still on base)
- 3in turboback exhaust
- Lightened pulleys
- Larger fuel pump
- Relocated battery to boot (drycell)
EXTERIOR
- Stubby aerial
- Rear wiper delete
- Modified front bar
- Aftermarket headlamps
- Clear side indicators
DRIVETRAIN
- Dieselgeek 5sp shifter
- Spec Performance Stage 3 clutch
- Billet single mass flywheel
INTERIOR
- Parrot headunit
BRAKING
-ECStuning Stage 1 upgrade (330mm front discs)
-EBC greenstuff pads (F)
WHEEL + SUSPENSION
- Raceland coilovers
- DLI Engine mounts (passenger & drivers side)
- BFI dogbone bushings
- Audi TT Mk1 wheels
