Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: AUDI A3 _BMN engine (2007) - HELP
    Jul 2011
    Perth
    I didn't chemically clean the DPF , noting comes out of it no dust.
    Apr 2008
    I’m impressed you did that. Most forum goers aren’t that savvy.
    Greg Roles spent a few hours with a Karcher, pushing the ash back out of the core, then drying it in the oven before putting it back in.
    So as I understood it, the ash/soot doesn’t just fall out, it needs to be pushed out
    Jul 2011
    Perth
    To keep this simple, I know lots of you guys looked at the youtube videos but when I took the DPF off , I could see through the cells.
    Anyway , Im gone past the DPF itself. Looking into combination of sensors again.
    Al
    Oct 2014
    Your ECU thinks your DPF is blocked.
    Do a forced regen
    Diesel Particle Filter Emergency Regeneration - Ross-Tech Wiki
    you may need to reset the dpf loading
    I had exactly the same issue.
