Originally Posted by
jgribben
Hey Matt. Really no expert and will probably be off but just wondering if you have tried it. My cars fuel pressure drops overnight so I have to turn the ingnition on and off 3 times without starting the car to build the pressure up then start it on the 4th. Seems to work ok for now (I thought my injectors were stuffed too). But if you do that and it makes the start better at least you'll know its to do with the fueling then go from there.
As I said before though no expert and never worked on that specific engine so could be well off the mark with what is wrong.
Plenty of mechanics on here though sure someone with chime in soon
Wonder who showed you that trick
It could have carbon build up, id try some Fuel x through it, you can buy a bottle at bursons. Also does the engine fast idel when cold?? it could have a throttle body issue, need a clean and reset. There is a few things that can be checked there. At least you can say its only cold so all hot running problems can be ruled out.
Jmac
ps ABC is a bomb proof motor
Alba European
