Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: Audi 80 V6 Help
    Mar 2015
    Launceston, Tasmania
    Audi 80 V6 Help
    So I've had this car for a bit over a year now, and I've slowly worked out all the kinks and issues with it.
    Car in question is a '94 Audi 80 V6 2.6 (ABC Engine) - Same as the early A4's, A6's, VW Passat's which had the 2.6 engine.
    Right now I'm down to the last one essentially.
    Basically whenever the car is cold started (that is the engine is cold) it will run really rough, as if it's stalling or misfiring until it warms up (about 50-60c) going by the temperature gauge on the dash.
    I do get a check engine light too but that dissapears really soon after starting. I have a feeling this is unrelated though, not sure.
    Things that have been done/tried
    • G62 Sensor Replaced
    • Oxygen Sensors Replaced
    • Cleaned the crankcase hose breathers (if that's what they are?)
    • Changed the Spark Plugs
    • Connecting a computer and clearing codes/viewing codes - No errors came up supposedly!
    One thing I haven't checked yet and don't know how to check is the injectors.
    Any input is appreciated!
    -Matt
    Nov 2014
    Hey Matt. Really no expert and will probably be off but just wondering if you have tried it. My cars fuel pressure drops overnight so I have to turn the ingnition on and off 3 times without starting the car to build the pressure up then start it on the 4th. Seems to work ok for now (I thought my injectors were stuffed too). But if you do that and it makes the start better at least you'll know its to do with the fueling then go from there.
    As I said before though no expert and never worked on that specific engine so could be well off the mark with what is wrong.
    Plenty of mechanics on here though sure someone with chime in soon
    Gosford Central Coast NSW
    Sounds like it might not be fuelling enough when cold. When the engine is really cold, the intake runners/head is cold enough that fuel will condense on the walls of the inlet/ports before it gets past the valves - hence petrol engines typically run very rich at cold start to ensure enough fuel is actually in the air going into the cylinder.
    I'm not familiar with that engine though so no idea really apart from what you have already replaced what could be the problem. I guess potentially a fuel supply problem might cause it, but you would be seeing other issues too like a lack of power. Is this the case?
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
    Mar 2015
    Well thanks for the input, I haven't really tested for power when it's cold as that's a bad to run the engine hard when cold..
    But when it's warm it can still go fast... Not posting how fast I've been in it but it's close to the original spec of the engine..
    (210kp/h)...
    Quote Originally Posted by jgribben View Post
    Thanks for the input! I've literally checked everything I can think of.. Next bet is replacing the fuel filter maybe, I'm thinking that maybe it can't get the flow it needs when it's cold or something?
    Actually I didn't mean when cold, I meant when warm. If it has plenty of power, the fuel supply is probably just fine. In that case its most likely a problem restricted to open loop mode for the ECU.
    Check if it cold starts any different with the coolant temp sensors disconnected.
    '99 A4 Quattro 1.8T
    Mar 2015
    I recently replaced that so it shouldn't make an issue surely?
    I actually ran it this morning cold start obviously and well..
    It only does it when it's in park, Neutral or Drive make it stop.
    While moving though i do get the constant stall and continue however.
    It's rather odd, had a few people look at it (1 mechanic/Audi guy) and they all have no idea what it is. I've literally replaced everything that people have thought it was so far.
    I realise you replaced the sensor but that doesn't rule out an issue related to open loop/ closed loop mode. Its worth trying, and doesn't cost a thing.
    '99 A4 Quattro 1.8T
    Aug 2007
    Wonder who showed you that trick It could have carbon build up, id try some Fuel x through it, you can buy a bottle at bursons. Also does the engine fast idel when cold?? it could have a throttle body issue, need a clean and reset. There is a few things that can be checked there. At least you can say its only cold so all hot running problems can be ruled out.
    Jmac
    ps ABC is a bomb proof motor
    Alba European
    Mar 2015
    Yeah that's true I suppose, sorry I actually overlooked that completely.
    Quote Originally Posted by Jmac View Post
    Jmac
    What's Fuel x / Any alternatives you could suggest as well?
    By fast idle you mean high idle, say over 1,200RPM? Yeah it does, when it warms up it drops to the 900ish mark.
    The throttle body looks kind of hard to get to.. I was told to try cleaning that by my local(ish) Audi wrecker/mate too.
    Just going to do it the same as the hoses by using degreaser and then washing it with water a few times.
    Good to know that she's bomb proof! :p
    Thanks for all the help so far guys!
    Quote Originally Posted by Matt86 View Post
    While moving though i do get the constant stall and continue however..
    ...this..... perhaps this is a vacuum leak issue related to the brake booster? The reason i suggest this is because when you start the car in park, your foot will probably be off the brake. When you change to N/D, you have to have your foot on the brake, and likewise when you try and move off you release the brake and from your description it sounds like you have the problem then too. If theres a crack in the booster diaphragm or something similar, that leaks when your foot is not on the brake but for some reason doesnt (or leaks less) when your foot is on the brake, it may account for the strange behavior.
    I suppose to test its probably pretty easy, disconnect vacuum to the booster and block it so you are sure theres no leaks, then see if the issue is still there or not. Obviously I would suggest you dont actually drive anywhere though!
    Just a thought.
    '99 A4 Quattro 1.8T
