Alright so an update, I finally got this sorted out!
Turns out it was a intake manifold leak, the top seal had been over-torqued and I went to replace the gasket and had the wrong one! Anyway I ended up getting an intake manifold from another 2.6 (there are two revisions so be careful, as well as a 2.8 being different again!). I won't go into detail about those though, basically 1991-1993 is type A, and 1994 onwards should be type B.
Anyway so yeah, that as well as my MAP sensor looked to be pretty bad, even after a cleanup with around 10x cotton buds and metho. Just going to get a SCA one and see if that improves it further.
I still do however get the warning lamp upon startup, do also note that I did break a vaccum hose (it was brittle/frayed anyway) and replaced that too. The one that goes from the left side of the throttle body to some weird plastic hose thing up top near where the heater hoses would go in.
Just a brief question, how should I bypass my heater core? I've had the hoses cut since I had the car but the "fix" that someone else has done happens to leak now..
Injectors came up fine also, all around the 14.5k ohm mark, I also found out that
these will fit.
