Results 1 to 8 of 8
Thread: Audi 80 2L engine code req.
    Jan 2008
    Melbun
    hi guys whats the engine code on the aussie delivered audi 80 2.0L's? they're from around 93 and have "2.0E" written on the back (of the car). are they ABA motors? cheers.
    2x Caddy, 1x Ducato
    Camden, Sydney
    They are 3A shortblock 2Ls. They are a bored out version of the 1.8 GTI Motors in the Golf 2.
    The ABA is a longer bubble block. and a crossflow head.
    New Beetles have a version of this motor.
    I have a couple of ABAs just landed from America. Sing out if you need.
    You can use a 2E 8v bottom end and an imported head, but you need to flycut the pistons.
    Jun 2006
    Orange NSW
    That's easy, you just need an old inlet and exhaust valve, some highspeed steel and a drill.
    Braze the HSS onto the valves and grind a cutting edge on them, then you can put the head on the block and flycut the pistons one at a time Using your head as the guide.
    Jan 2008
    Melbun
    is flycutting the pistons taking some of the top of the pistons off? this thread looks like its going to go over my head real soon
    wouldnt it be easier to save the trouble and just use an aba block with abf head?
    2x Caddy, 1x Ducato
    just making room for the valves to go down so the pistons dont hit them at the top of the piston stroke. thats a good idea preen ill have to try that one day.
    cheers brenton
    MK1 4door
    MK2VR6
    MK3VR6
    Transporter
    and untold wrecks
    Perth. WA
    U need put a stop collar on the valve stem so you dont cut the piston crown to far, and to make all piston cut outs the same ( close as you can anyway.. )
    Lots of MK 1 Scirocco's...
    Cheers,
    Grant...
    Camden, Sydney
    Quote Originally Posted by Mischa View Post
    LOL. Where would you get either of them in Australia??
    Jan 2008
    Melbun
    surely a head isnt too hard to import?
    anyway there goes my original idea of the 80 having an aba
    2x Caddy, 1x Ducato
