Results 1 to 10 of 12
Thread: Audi 100 no start
    imported_brackie Guest
    Audi 100 no start
    The Loon and I spent an hour in the rain yesterday afternoon trying to get my old Audi (now belongs to our milking hand) going. It's a 5E with Kjet and electronic ignition.
    Checked:
    Timing. OK (thought that the belt may have jumped a tooth or two..It's old and stretched.)
    Fuel. Spray at injectors and throttle plate lifting
    Spark. There but weak.
    Suspect coil or ignition module.
    Any ideas Guys?
    syncro Guest
    This model uses an inductive pick up in the distributor instead of a hall transitor that the later models use. The pick up is really just a coil of wire and have been known to go open circuit. There should be a two pin plug on the side of the distributor (hall sensors have three pins) Use a meter to check continuity, and you can find the specifications, check the resistance.
    The electronic module I think maybe similar to an old Magna (Bosch) module if you nead to check that.
    Check the resistance of the plug connectors and that the correct coil is fitted.
    Phill
    Thanks!
    Goodonya, Phill! That's a most comprehensive reply. I'll get onto it tomorrow (weather permitting!) If the hall transitor has gone open circuit would there still be a spark at the plugs?
    syncro Guest
    Re: Thanks!
    Quote Originally Posted by brackie
    Read again, they don't have a hall transistor!
    2 wires
    It has a 2 wire connector.
    syncro Guest
    Re: 2 wires
    That's what I thought.
    Camden, Sydney
    So where do you check for continuity then?
    syncro Guest
    The distributor. It's just a coil.
    Apr 2006
    Hobart,Tas
    Had a 911 the other week Brackie that had no spark. Borrowed a sigma dizzie, connected up and spun the shaft. I had a 40m/m spark coming from the coil lead! Windings crook in Porsche dizzy. Petrojet for nem one, Cost me $140. Carefull when testing though! Can hurt you bad! I have a complete 5+5 that goes if you want it. $200
    No petrol bits!
    In my little world of diesels I have very little petrol engine stuff. I you guys reckon the dizzy's stuffed where do I get one? (Mate, if I put that 5+5 on my block my mrs would kill me!)
Similar Threads
  1. Volkswagen Group Australia Sales Stats (Audi, SEAT, VW, VWCV) 1991-2008
    By phaeton in forum VW Watercooled Media Lounge & Interesting Articles
    Last Post: 08-11-2010, 10:52 AM
  2. Audi S5 Unveiled @ MIMS 2007
    Last Post: 07-03-2007, 01:14 AM
  3. Audi S3 brake upgared (Caliper painting)
    By PoloGTi in forum Polo (9N & 9N3, 2002 - 2009)
    Last Post: 26-11-2006, 01:42 PM
