Hmm very interesting Gav!!!!!!![]()
I have been busy this evening after getting in from work. The other week I got my data logger working finally. I had been trying to use the coilpack trigger to feed the logger for engine speed. I have seen this done and done it myself but couldn't get a reliable reading.
Everyone was telling me to use the tach output from the ECU. Anyway after a gave up and did that it worked first time.........
I took some logs about 2 weeks ago and got the new software in the week. C-C have been mega busy.
Kev says to do some logging and reduce the boost with the actuator. I asked how much, he says drop it to 22PSI, I said that didn't seem like much fun as I have enjoyed 27 since I first loaded the trial map.
His response was that bent rods aren't that much fun either
So I loaded it up and took a few pictures. I have started it up and driven around the block. I'll try and do some logging this weekend and see how it has improved.
Alba European
I added a dodgy switch into the loom tonight, one I pulled from a old Cessna. You can see it near the leatherman.
When you do the flash you have to reboot it and it was a pain in the a$$ to unplug it from the power to do it.
It worked a treat, I'll have to do it for the other 2 bench leads I have as well.
