Results 21 to 30 of 33
Thread: Almost ready to do a 'look what I did to the A3' thread.
  1. #21
    Dec 2007
    Melburg East VIC
    i cant post in the business section so i'll have to ask you here.
    i've just looked at CC prices, 246 pounds is about $500au, what map does this apply for? a k03/k04 flash they already have? once you start customizing the map to suit your setup how is this charged? from what i understand you a probably using the their base k04 map and getting it altered to suit your setup?? it seems that CC should be able to make big turbo files for agu? sort of like revo does for dbw US cars.
    if someone installed a gt28 for example, run it on a k04 map, do some logging, send it off to you, you send it to CC then they should be able to adjust the map to suit that particular setup?
    what blocks need be logged for agu? cheers!
    1.8T AGU | K04 | GIAC | 380cc | VR6 MAF | Custom Intake | FMIC | TIP | 3bar FPR | N75J | 42DD 3-2.5" TB | GFB DV | FK Highsport | ECS Stage 1 Clutch | OZ FUTURA
  2. #22
    Quote Originally Posted by schwartza3 View Post
    That map will be a Phase 1 for your car. 'Off the shelf" if you like.
    You can't do direct comparisons on pricing like you have based purely on exchange rates. No-one else in the game does. I can't see Guy Harding doing flashes which are effectively the same money as the states.
    Before I make any statements about how much it would cost to map and car for you. I think we need to talk about where you are headed.
    Essentially, you are right though. Log, adjust, reflash. Much easier if you have something on file which you can use as a starting point.
    You need to do some external logging with the AGU as the ECU doesn't have a built in MAP sensor.
    PM will be sent with my number.
  3. #23
    Dec 2007
    Melburg East VIC
    cool
    i understand that the price is for uk customers, just wanted to ask how is the customizing of the map charged compared to the base price as the map needs to be refined.
    obviously the base price will have a markup to start off with. pm recieved
  4. #24
  5. #25
    Point Cook, Vic
    clutch forks bending and breaking is a common failure in 02As as well ive heard.
    FOLLOW US ON FACEBOOK
  6. #26
    Quote Originally Posted by Tim View Post
    Yeah, just found that out after talking to jmac, wish I'd heard that 2 weeks ago...... Would have saved me a day.
    Live and learn
  7. #27
    at least you caught it before it broke
    cheers brenton
    MK1 4door
    MK2VR6
    MK3VR6
    Transporter
    and untold wrecks
  8. #28
    Quote Originally Posted by DVR68U View Post
    cheers brenton
    Yeah Brenton, something about thankful and small mercies.
  9. #29
    hey gavin in my mk2 vr6 i have the cable clutch conversion, and the bracket that holds the cable on the box ( where the mk1 gbox mount is) was bent back 15mm by someone. this was causing it to hit on the shifter when you tried to go into 2nd. i bent it back and now my clutch pedal is super far out and the clutch slips.?? but i can get 2nd . its in the postion the bracket is supposed to be. its like the cable is to short, or maybe the clutch forks are bent ? the vr6 clutch on a cable mech is very heavy lol
    what do you guys recon
    cheers brenton
    MK1 4door
    MK2VR6
    MK3VR6
    Transporter
    and untold wrecks
  10. #30
    I don't think the cable conversion was supposed to handle the clutch you need with a VR engine.
    The hydraulic is much better.
