Hey my friend i can help. This code is in 2 places, firstly there should be a bar code sticker on the rear of your tappet cover ( under the plastic cover) and secondly it is teaped onto the engine block on a surface on the block. Ok looking at the the engine where the inlet manifold is roughly around number 3 cylinder there is a gap in the inlet manifold. Look at the engine block and there is a surface about 2 inches long with ADR****** stamped on it. Look at your dipstick and should be behind it to the right.
Jmac
