![Quote](https://www.vwwatercooled.com.au/forums/images/misc/quote_icon.png)
Originally Posted by
h100vw
Those modules won't prevent it from running. The immobilisation will though. Custom-Code can defeat the immobiliser at the same time, as carrying out a flash. There is an extra cost involved but nothing in the grand scheme of things.
This would be less effort than MOTEC and the following tuning that would be required.
Another option would be doing the same as Golf Loon has done with his Scirocco. That uses DTA IIRC but comes with software to up the power as part of the package.
B6 is a nightmare Gav, i looked at putting a manual in mine if the CVT goes south, way too costly for it, Engine ECU and dash cluster, if the Airbag and ABS are missing on that car he might well have dramas, you loose the Can signal, Ive just looked at Treg with Crash data , crash signal cut the start signal for the engine ECU, and if you remove the airbag ecu it still wouldnt start, it had to be physically erased to allow it to start, not sure about the B6 really but i know from conversations with the guys in the Uk they are tricky correct me if im wrong, you will at least need the cluster that is matched to an existing ecu including keys and reading spool. You could go with what Loon has or call Troy at EFI Performance 38018075 they supply many set ups, mainly for the high horse stuff but he would point you the right way if not. He is well switched on, ive attended tuning seminar that he held and ive booked well ahead for the follow ups. Give him a ring.
Jmac
Alba European
