Originally Posted by
t4 camper
Hi,
I am trying to find out the correct oil pressure spec for my wifes A4 B6 1.8T.
The oil light came on the other day when she was driving, thought it was low level warning (yellow). After she consulted the book she told me it was the pressure light, red.
I measured the pressure this morning and it is surprizingly low.
Cold was 25-30lbs (180-210kpa)
when engine was hot 20-25lbs (150-180kpa).
My searches so far have not revealed the specs.
The car is a 2003 done 80 000k.
I was suspecting a faultly sender but tested the pressure before blindly replacing the sender.
If it is low, is the pump and pressure relief valve accessible from underneath by dropping the sump?
Thanks Neil
Hi Neil, you need to get the oil feed running to the heads checked as this model has a known oil sludge build up issue. The oil feed is about the size of a 20c piece according to an Audi tech I spoke to and, in is words "pathetic for a performance engine"(it was subsequently increased in size to overcome this "non-existent" issue in later models, Audi deny this has ever been the case). go to audioilsludge.com and check for yourself. Audi in the US increased engine warranty after the fix but still deny the engine is seriously flawed, yeah right! oh, and if it does let go? about 16-20k should see you right or buy a second hand engine.
Mini Cooper S Chilli- when I can pry the keys
Carbon Steel GTi 19" BE by Breyton,LED tail lights, NEW 8" Nav !
Facelift Daytona Grey A5 Sportback, S-line 19" Titanium Rotors
