Nah!
I predate social media/selfies by too many decades.
The biggest risk relates to vulnerable low profile 'performance' tyres getting staked or cut.
You ford a stream to get from Bindaree Falls to Howqua Hills so best before sig rain otherwise no problems and ends up a round trip avoiding the tourist road altogether.
If yr into camping Sheepyard Flats/Howqua Hills looks good but I guess popular also.
ok no worries ive got all terrain dualers on my tiguan in light truck construction so should be all good there . i always use a water blind on the tiguan for any water deeper then the bottom of the number plate .i tow an old vintage caravan so no good for any off road camping .
I was thinking of a set of steels with 215/65/16s ATs which would make the speedo more accurate I'm thinking.
that is the standard size for the tiguan so the only difference is the overall size due to tread depth
The only actual 4WD section is the Craig's Hut access track - the Falls - Sheepyard Flats is just gnarly.
- You may not post replies
- You may not edit your posts
Forum Rules
