Results 1 to 10 of 12
Thread: Skoda Yeti Ambition 90TSI - reliable or not?
    Aug 2013
    Newcastle, NSW
    How have others found the reliability of the Skoda Yeti Ambition 90TSI?
    The MY14 Skoda Yeti Ambition is ideal for my needs and I really love it. However there has been a few issues and I have not had a warranty claim on any new car (Japanese, British, German built) since the late 1980's except for the VW Polo I had prior to the Yeti. The Yeti is not even 2 years old and has less than 10k mileage. Since this is based on the Golf Mk V platform with recent tech updates, I would have thought it would be a well sorted stable design.
    There's been nothing major but not what I would have expected from a new car these days (I understand other brands have issues as well).
    * DSG hiccups at times with holding onto gear at a constant rev and not changing up for a few seconds - dealer check and no error logged (no fix)
    * Instrument panel creaks - dealer attempted fix but still creaked - self repair with 2mm felt placed at offending areas
    * Full throttle failure on several occasions where engine would not spool up for a few seconds - dealer check and no error logged (no fix)
    * Whirr noise LH front when on RH curves - dealer replaced wheel bearing - self organised tyre rotation and and 4 wheel alignment (better but still present)
    * RH front headrest creeps up to unsafe height - dealer no fix - self repair velcro tie headrest to seat
    * Doors occasionally failed to unlock via KESSY - dealer advised CAN BUS can go to sleep if not used for a while - self fix change battery in remote
    * Dash lights disappearing in daylight (not the dark tunnel effect) - corrected itself
    * Whistle noise in engine bay TPI2041310/4 - dealer changed water pump and seal
    * Ticking noise heard through vent on dash when car stopped after normal use. Sounds like a tappet noise or a vacuum pulse or non return valve ball banging on the seat. Doesn't do it cold and when happens, disappears after engine shutdown and restart. Just started so will leave for the next service next month.
    As I said nothing major but still concerning as I wanted to keep the Yeti for 6 years. The service dealer have been very good and have listened to my concerns. Some they fixed, others not but I'm not complaining as they have made the effort.
    Oct 2015
    Adelaide, South Australia
    Hey Rabbitz,
    I have a MY15 Yeti Edition with the same 90tsi engine. One time engine was stalling a lot - figured out it was due to filling up with 95ron shell fuel - once fuel cleared it was back to normal - only fill with 98ron BP now. Only other issue ive had am still having is the DSG sometimes whines going through gears 1,2 & 3 (usually after 20 mins + driving time in stop start traffic) - have read this pretty common and no real confirmed solution. I've got a 5 year warranty so not stressing too much about it. Other than that - im loving the Yeti - easy best and favourite car ive ever owned
    Aug 2013
    Newcastle, NSW
    I had a problem with Shell 95 in a WQ Fiesta years ago and swapping over to BP 95 fixed it. I use BP 95 in the Yeti and all good. The DSG is a bit dimwitted at times on inclines so I just use manual mode on those occasions. Yep, it's a great car.
    I only asked the original question as it's a pain to return it to the dealer for repairs, get a ride home and back plus it can be off the road for weeks waiting on parts. The water pump was supposed to take 3 weeks to arrive from Skoda EU but I think someone just wandered over to the local VW dealer who stocks heaps of parts, so it was done in 2 days.
    May 2011
    Mickleham, VIC
    hi. i have a 90tsi yeti 2014.
    i have had an issue with the front left cv boot splitting. standard cv joint clicking / knocking with some lock plus seems to be affect bearings as well, at 100kmh you can hear a very low frequency rumble noise. been fixed oncw but came back after 20000km, am happy with the car just a few niggles with it. i have the bi-xenon headlights and they are amazing. plus 12 speaker sound. leather seats are awesome as well.
    Aug 2013
    Newcastle, NSW
    Looks like the Yeti TSI Ambition has been discontinued.
    Bowral, NSW
    Quote Originally Posted by rabbitz View Post
    Thats correct.
    Skoda is now only offering two specifications of the Yeti (the Ambition 92TSI used to be the third, middle spec) - those being the 81TSI and the 110TSI 4X4 Outdoor.
    2012 Octavia vRS TDI. Darkside big turbo, 3bar tune, other stuff. 200kW/650Nm.
    1990 Mk1 Cabrio. 1.9 IDI w/ 18PSI.
    1985 Mazda T3500 adventuremobile. 1973 Superbug. 1972 Volvo 144 in poo-brown.
    Not including hers...
    Oct 2015
    90TSI Yeti booked in today to have updated Clutch Packs replaced to alleviate whining noise during up gear changes. Solitaire Automotive in Adelaide agreed with my diagnosis straight of the bat - all done under warranty, no questions asked - great service!
    Aug 2013
    Newcastle, NSW
    At what kilometres were the clutch packs changed?
    Oct 2015
    Hey Rabbitz - still waiting for them to come in but will have done less than 20,000kms
    Aug 2013
    Newcastle, NSW
    That's not a great life for a clutch pack.
