Quote Originally Posted by Blue103TDIDSG View Post
Boon
I'm no "expert" in these matters but have been looking at this very issue since before we got our Yeti nearly 12 months back. The 80kg refers to down force on the ball, the actual load the trailer puts on the back of the car The result for us was that we had to decide to sell our caravan if we went ahead and got the Yeti because the ball weight was over 130kg even though the all up weight was 1400kg - well under the 2000kg limit
Can't imagine the all up weight of a jetski and trailer being anywhere near the 2000kg mark, so it is just the ball weight you need to look at and with a jetski and trailer you should be able to gauge the ball weight just by lifting tow coupling by hand as they are generally pretty well balanced to allow for maneuvering by hand.
I am restoring a boat trailer for a rubber duckie with a 30hp engine at the moment and it will be set up so that there will be about 25kgs on the ball. The ball weight of this trailer can be adjusted by moving the boat to change the balance point so it is no big deal, but I want it nice and light for hand maneuvering into a storage shed
It seems on heavier things like vans, the compliance plate has 2 weights, GVM and I think ATM (someone please correct me if I am wrong here) One is the all up weight that the vehicle can carry including the vehicle itself and the other is the weight the axle or axles can carry. Obviously one is higher than the other and the difference is the ball weight. Some compliance plates actually have the ball weight - I have seen both types.
The simplest way is to get some electronic bathroom scales and a piece of 3x2 timber about 15" long plus another couple of pieces of 3x2 about 6" long. Wind the jockey wheel down to where the van is level or better to the height it will be on the towball, insert the timber and scales under the coupling, then slowly raise the jockey wheel. When the jockey wheel is off the ground the scales will tell you the ball weight
Did this on my (old) caravan and a mates Adria - his came in at 52kg ball weight, mine came in at 132kg
Similar featured vans, mine Australian and his European - won't get into that argument here but the Yeti is obviously designed for the Euro van designs.
Hope this helps
Here is quite a good explanation of vehicle and van weights Caravan / Trailer Compliance Plates and Weight Explanations
However there is one glaring omission which lots of vanners don't observe or don't know about.
The towball weight on the vehicle is part of the payload.
Hence if you have a Landcruiser which has a payload of about 672kg it works like this Fuel 135kg, towball weight 275kg =410kg leaving you 262 kg for you and mum and any gear you have in the back. So you 100kg. mum 60kg leaves 102 kg for all the stuff in the back.
So don't even think about a roof rack (40kg) and a tinny ???? and an outboard stuck underneath it, 2 jerry cans of diesel in the back etc..
Been there done that. Went over weighbridge, went home dumped a heap of stuff and went touring.
Even worse if you have a Prado or a Nissan with reducing ball weight limits over a certain figure.
Not all will have a van with that much ball weight but ours was actually 300kg and 2900kg ATM.
