I didn't take any photos with the bumper off or how the actual tow bar was fitted. It’s really simple though. The bumper comes off by removing these covers:
Like this:
And then you can remove these nuts:
There are 4 plugs/clips under the bumper. 2 screws at the edges which join the bumper to the inner guard and that’s about it. The bumper is not much more than a cosmetic thing. There is nothing solid behind it, which is a good thing when someone bumps you in a car park. You might break a couple of clips but the plastic bumper should bounce back and since it’s not painted it shouldn’t show a scratch too bad.
Once the bumper is off, there is a pressed metal bar that needs to be removed. There are 3 screws in one end and 4 in the other, if I remember correctly. It gets chucked out.
The tow bar itself is very simple. There are 2 flat, vertical tongues that insert into the ends of the chassis. Then 2 bolts screw into the tongues from inside the wheel arches. There is a large square tube that runs across the back of the car with the socket for the tow hitch in the middle. All the bolts have torque settings so a Torque Wrench is needed to get the right tension on the bolts.
Here is the socket visible with the cover off:
And the cover on:
