Results 1 to 7 of 7
Thread: Columbus Unit Installation
    Sep 2012
    Australia, Kelvin Grove
    I've managed to get hold of a Columbus unit for a good price - is it simple to install? Any specialist tools required? Thanks.
    Re: Columbus Unit Installation
    Only physical tools required are trim removal tools and torx driver.
    But car will likely need to be recoded using vcds.
    what car is it going into and what head unit is it replacing?
    Sep 2012
    Thanks for the reply - it's going into a Yet, replacing the Bolero.
    Sep 2012
    I need to sell the Bolero unit - any idea how many posts are required before I am allowed to post a classified? Thanks.
    Dec 2006
    Kilsyth, VIC
    Just be a bit careful with the facia plates...
    In the all the VW's I have done the facia plate is the same between the RCD and the RNS so it's a quick and simple swap out...
    I know SFA about the Yeti, but the last Skoda I did had a difference facia plate for the basic radio vs the nav unit. Getting the right replacement part was a PITA and took the dealer three attempts to get the correct one
    In the one I did they just left the facia plate off while waiting for a new one, bit I thought it was worth mentioning.
    A Quick poke in ETKA seems to show at least three different variants:
    Columbus Unit Installation-yeti1-pngColumbus Unit Installation-yeti2-png
    Sep 2012
    That's really helpful - thank you. Looks like I need 5L0 8585 069 L trim for switch for vehicles with navigation system air conditioning system with electronic regulation (112TSI).
    Dec 2006
    Kilsyth, VIC
    I'd pull out the old part and check what part is currently in there, ie match it to one of the above first to give some confidence that the one you think you need is the correct one.
    (FYI in the Octavia I did (I think it was an Octavia anyway) there was two or three different styles (depending on what sort of AC you had) then on top of that a different variant for each audio option + then colours )
