Results 1 to 6 of 6
Thread: VW LT35 Van
    GEELONG
    VW LT35 Van
    Hi Guys......any dirt on the LT35 and how it compares to the Mercedes Sprinter?
    Thanks
    Jan 2007
    South Australia
    Well it is the only van in the segment that was built in Germany.
    VW drivetrain I'd imagine to be cheaper to service as there are many 2.5 TDIs on the market.
    Sprinter is market leader so if you want to be different go LT :
    - Ben
    1961 Karmann Ghia Coupé - 1993 Golf Cabriolet - 2006 Golf Comfortline 1.9L TDI
    2008 Jetta 2.0L FSI
    May 2006
    Adelaide South Australia
    Quote Originally Posted by phaeton View Post
    VW drivetrain I'd imagine to be cheaper to service as there are many 2.5 TDIs on the market.:
    I know the diff is Mercedes & my guess so is the gearbox, it's slow enough to be. Engine [VW] is good though.
    Numerous Mk1 Golf diesels
    Jun 2006
    with the dust and flies in western Victoria
    Quote Originally Posted by DOUBLECAB View Post
    The LT35 is a Sprinter....apart from the panels forward of the A-pillar and the driveline (the engine and gearbox anyway).
    As for dirt....big, slow and noisy. A bit like the Sprinter....
    May 2006
    The Brickyard has a section for LT series, you will have to join to read it though.
    http://www.brick-yard.co.uk/forum/lt...ums_cat13.html
    queanbeyan, NSW
    The LT is largly a PREfacelift T1N series Sprinter with the only difference being front sheet metal, engine and tail lights oh and the 3rd brake light! It even used the old Sprinter dash board and floor mounted gear lever. Personally I can't see the point of getting an LT unless 1:you are already very well versed on the VW 2.5 TDI 2: it's cheaper then a same year Sprinter, which I suspect it will be. Annoyingly I can't rememeber any technical specs of the LT and I did the predeliver work on all the launch vehicles!
