Second Generation LT
2nd gen. LT28 operated by a german "Behindertenfahrdienst" (handicap transport service)
Conception History
The demand for the first generation LT is defined by the exceptionally long period for which it was manufactured. After 21 years and just under half a million vehicles, shortly after the foundation of the Volkswagen Commercial Vehicles brand in 1995, came the second generation of the LT in 1996.
In 1996 Volkswagen Commercial Vehicles and Daimler's Mercedes-Benz Commercial unit signed a deal confirming that the second generation LT would share a body shell with the new Mercedes-Benz Sprinter, however the engine and transmission would be Volkswagen sourced. This deal would continue on in the Volkswagen Crafter, successor to the LT.
Design
As with the new Volkswagen Eurovan (Transporter T4), the second generation of the LT abandoned the one-box design in the cab-over-engine construction which had characterized Volkswagen utility vehicles for over four decades. With an engine mounted longitudinally beneath a short hood and with rear-wheel drive, the LT now adopted what had become the standard style of construction for bigger transporters.
In addition, it satisfied requirements which remain sought-after even today: economical direct-injection diesel engines, easy access to the driver cab behind the front axle, and a wide space between the driver and passenger seat.
Range
The range now went from 2.6 to 4.6 tons gross vehicle weight, and the enclosed options of the panel van and compact were available in three wheelbase options. Platform vehicles, crewcabs and numerous undercarriage options completed the range. A special articulated version of the second generation LT, the XLT was available through special order.
Engine
With a naturally-aspirated engine as well as three TDI engines, Volkswagen Commercial Vehicles answered the call for economical and high-performance diesel engines. The basis for this was the same five-cylinder TDI which had already established a positive reputation in the Volkswagen Eurovan (Type 2 T4) within a very short period of time.
For the first time, Volkswagen had profited from synergies between the two major in-house transporter series.
The performance range for the LT initially went from 61 kW (83hp) to 96 kW (130hp). In January 2002, Volkswagen Commercial Vehicles again raised the bar; a particularly powerful four-cylinder 2.8l engine increased power output to 116 kW (156hp) and the maximum torque to 331N·m. At that time, these were once again record figures among vehicles in its class. Compared to the most powerful engine on the first generation LT, it represented an increase in torque and performance of over 50%.
The 2.8l engine's specifications were as follows:
* 2,789 cc 2.8l 4-cylinder engine with 93 mm bore, 103 mm stroke and three valves per cylinder
* Power: 116 kW, 158 hp EEC @ 3,500 rpm, 331 Nm (244 ft·lbf) @ 1,800 rpm
* Diesel common rail fuel system
And the 2.5l:
* 2,461 cc 2.5l 5-cylinder engine with 81 mm bore, 95.5 mm stroke, 19.5 compression ratio and two valves per cylinder
* Power: 80 kW, 109 hp EEC @ 3,500 rpm, 280 Nm (210 ft·lbf) @ 1,900 rpm
* Diesel direct injection fuel system
Retirement
The second generation LT was manufactured for over nine years in total, with practically no external changes; testimony to its build quality. By the end of production in the 4th Quarter of 2006, around 350,000 models had come off the production line.
Plans for the third generation of the 'large transporter' from Volkswagen Commercial Vehicles had already gone underway, and later that year the Volkswagen Crafter was launched.
